WhatsApp Compatibility: Which iPhone Models Will Still Work in 2025?
WhatsApp, the popular messaging app owned by Meta, regularly updates its software to improve features and security. However, these updates sometimes mean older devices lose compatibility. For iPhone users, a significant change is coming in 2025 that will affect which models can continue using WhatsApp.
WhatsApp’s 2025 iPhone Compatibility Update
Starting May 5, 2025, WhatsApp will no longer support iOS versions older than 15.1. This change will impact several iPhone models that cannot be updated to newer iOS versions.
Affected iPhone Models
The following iPhone models will lose WhatsApp support in May 2025:
  • iPhone 5s
  • iPhone 6
  • iPhone 6 Plus
These devices are limited to iOS 12 and cannot be updated further, making them incompatible with WhatsApp’s new requirements.
iPhone Models That Will Remain Compatible
Fortunately, most recent iPhone models will continue to work with WhatsApp after the 2025 update. Here’s a list of compatible devices:
  • iPhone 7 and newer (including all Plus, Pro, and Max variants)
  • iPhone SE (2nd generation and later)
As long as these devices are running iOS 15.1 or newer, they will maintain WhatsApp compatibility.
Why Is WhatsApp Dropping Support for Older iPhones?
There are several reasons why WhatsApp periodically ends support for older devices:
  1. Security: Newer iOS versions include important security updates that older devices can’t receive.
  2. Features: Modern WhatsApp features may require capabilities not present in older hardware or software.
  3. Performance: Ensuring a smooth user experience on increasingly outdated hardware becomes challenging.
  4. Development resources: Supporting a wide range of old devices takes time and effort away from improving the app for the majority of users.
How to Check Your iPhone’s iOS Version
To determine if your iPhone will remain compatible with WhatsApp, you need to check its current iOS version and update capability.
Step 1: Open the Settings app on your iPhone.
Step 2: Tap “General”, then select “About”.
Step 3: Look for the “Software Version” entry. This shows your current iOS version.
Step 4: If your version is below 15.1, go back to the General menu and tap “Software Update” to see if a newer version is available.
If your iPhone cannot update to iOS 15.1 or later, it will lose WhatsApp support in May 2025.
Options for Users with Incompatible iPhones
If you find that your iPhone won’t be supported after May 2025, you have a few options:
  1. Upgrade your iPhone: Consider purchasing a newer iPhone model that supports current iOS versions.
  2. Use WhatsApp Web: You can still access WhatsApp on a computer through the web interface, though this isn’t a long-term mobile solution.
  3. Switch to alternative messaging apps: While not ideal, you might need to explore other messaging platforms that still support your device.
Preparing for the Transition
For those who need to upgrade, it’s important to properly transfer your WhatsApp data:
Step 1: Open WhatsApp and go to Settings > Chats > Chat Backup.
Step 2: Tap “Back Up Now” to ensure your latest messages are saved.
Step 3: When setting up WhatsApp on your new device, you’ll have the option to restore this backup.
WhatsApp’s evolving compatibility requirements mean some iPhone users will need to make changes in 2025. By staying informed and planning ahead, you can ensure continued access to this essential communication tool.
