iPads have become incredibly versatile devices for both work and play. With the right accessories, you can transform your iPad into a powerful tool for productivity and creativity. Let’s explore some of the best iPad accessories available in 2025 to help you get the most out of your tablet.
Protective Cases
A good case is essential for keeping your iPad safe from drops and scratches. Here are some top options to consider:
Magnetic Folio Cases
Magnetic folio cases offer excellent protection while adding minimal bulk. The ESR Flip Magnetic Case is a popular choice, featuring:
- Multiple viewing angles for comfortable use
- Secure Apple Pencil holder
- Auto sleep/wake functionality
- Available for various iPad models including the latest iPad Pro, Air, and standard iPad
Step 1: Choose a case designed specifically for your iPad model.
Step 2: Align the iPad with the case and let the magnets snap it into place.
Step 3: Fold the cover back to activate different viewing angles.
Rugged Cases
For those who need extra durability, rugged cases provide military-grade drop protection. The OtterBox Defender Series offers:
- Multi-layer protection with inner shell and outer slipcover
- Built-in screen protector
- Port covers to keep out dust and debris
- Doubles as a stand for viewing or typing
Screen Protectors
A quality screen protector can prevent scratches and reduce glare. Here are two types to consider:
Tempered Glass Protectors
Tempered glass offers the best clarity and touch sensitivity. The ESR UltraFit Classic Screen Protector provides:
- 9H hardness rating for scratch resistance
- Oleophobic coating to reduce fingerprints
- Easy installation with included alignment frame
Step 1: Clean your iPad screen thoroughly.
Step 2: Use the provided alignment tool to position the protector.
Step 3: Press from the center outward to adhere the protector, removing any air bubbles.
Paper-Feel Screen Protectors
For artists and note-takers, paper-feel protectors provide a more natural drawing and writing experience. The ESR Paper-Feel Magnetic Screen Protector offers:
- Textured surface that mimics paper
- Magnetic attachment for easy application and removal
- Reduced glare for better visibility outdoors
Stylus Options
A good stylus can greatly improve your productivity when taking notes or creating digital art. Here are some top choices:
Apple Pencil
The Apple Pencil remains the gold standard for iPad styluses, offering:
- Pressure sensitivity and tilt recognition
- Low latency for a natural writing/drawing feel
- Magnetic attachment and wireless charging (2nd gen)
- Integration with iPadOS for advanced features
Third-Party Alternatives
For a more budget-friendly option, consider the ESR Geo Digital Pencil:
- Compatible with iPads released since 2018
- Palm rejection technology
- Tilt sensitivity for shading
- USB-C charging
- FindMy app integration to avoid losing it
Keyboard Cases
Turn your iPad into a laptop replacement with these keyboard case options:
Magnetic Keyboard Cases
The ESR Rebound Magnetic Keyboard Case offers:
- Backlit keys for working in low light
- Large trackpad for precise cursor control
- Detachable keyboard for flexibility
Step 1: Attach your iPad to the magnetic back cover.
Step 2: Position the keyboard and let the magnets align it.
Step 3: Adjust the viewing angle as needed.
Folio Keyboard Cases
For all-in-one protection and productivity, consider the Logitech Combo Touch:
- Detachable keyboard with backlit keys
- Large trackpad supporting multi-touch gestures
- Adjustable kickstand
- Protective case with Apple Pencil holder
Stands and Mounts
A good stand can improve ergonomics and versatility. Here are some options:
Adjustable Tablet Stands
The Twelve South HoverBar Duo offers:
- Flexible positioning for various use cases
- Compatible with multiple iPad sizes
- Sturdy construction for stability
Wall Mounts
For a fixed setup, consider the Elago Home Hub Wall Mount:
- Securely holds your iPad on the wall
- Perfect for using iPad as a smart home controller
- Allows for easy charging while mounted
Hubs and Adapters
Expand your iPad’s connectivity with these accessories:
USB-C Hubs
The Anker 7-in-1 USB-C Hub adds:
- HDMI port for external displays
- USB-A ports for legacy devices
- SD card readers for photographers
- 3.5mm audio jack
- Pass-through charging
Audio Adapters
If you need to use wired headphones, the Apple USB-C to 3.5mm Headphone Jack Adapter is a simple solution.
These accessories can significantly boost your iPad’s functionality, turning it into a more versatile device for work and creativity. Consider your specific needs and use cases when choosing which accessories to invest in. With the right combination, your iPad can become a powerful tool for productivity on-the-go or a central hub for your digital lifestyle.
