The 7 Best PowerPoint Clickers for Presentations in 2025
In today’s fast-paced professional world, delivering impactful presentations is more crucial than ever. A reliable PowerPoint clicker can significantly enhance your presentation experience, allowing you to move freely and engage with your audience without being tethered to your computer.
But with so many options on the market, each with varying features, choosing the best clicker for your needs can be confusing and time-consuming. To help you make an informed decision, we’ve researched and compiled a list of the 7 best PowerPoint clickers available in 2025.
Logitech Spotlight Presentation Remote (Best Overall)
The Logitech Spotlight takes the top spot on our list, and for good reason. This advanced presenter remote goes beyond traditional laser pointing with its digital spotlight feature.
Key Features:
  • Digital spotlight for highlighting and magnifying content
  • 100-foot wireless range
  • Bluetooth and USB connectivity
  • Vibration alerts for time management
  • Rechargeable battery (1 minute charge for 3 hours use)
  • Compatible with Windows, macOS, iOS, and Android
The Spotlight allows you to precisely highlight and magnify areas on your screen, visible both in-person and via video conference. Its sleek design includes just three buttons for intuitive control.
The Spotlight presenter vibrates to remind you when it’s time to wrap up. It vibrates five minutes before the end of your presentation and again when your time is fully up. Time management couldn’t get better.
Price: $84 to $108.99
Kensington Expert Wireless Presenter (K72425AM) (All-rounder)
The Kensington K72425AM stands out with its unique joystick feature, essentially functioning as a portable mouse.
Key Features:
  • Joystick for cursor control
  • Red laser pointer (green laser available in other models)
  • 150-foot wireless range
  • Four intuitive buttons
  • Ergonomic design for comfortable holding
This presenter allows you to not only navigate slides but also interact with your content using the cursor control. It’s an excellent choice for those who need more interactivity during their presentations.
Price: $53.54
DINOSTRIKE 2 in 1 Type C and USB Presentation Clicker (Best Air Mouse Control)
For those seeking versatility, the DINOSTRIKE 2-in-1 clicker offers both Type C and USB connectivity options.
Key Features:
  • Air mouse control functionality
  • Dual connectivity: Type C and USB
  • Red laser pointer with 164-foot range
  • Multiple intuitive buttons for various functions
  • Ergonomic design
This clicker stands out with its air mouse control, allowing you to play/pause videos, switch windows, open hyperlinks, and more. It’s a plug-and-play device, requiring no software installation.
Price: $22.99
DINOSTRIKE Wireless Presenter Remote (Best Budget Option)
If you’re looking for a simple, affordable option, the DINOSTRIKE Wireless Presenter fits the bill.
Key Features:
  • Sleek, pen-like design
  • Red laser pointer with 300-foot range
  • Various functions including volume control and black screen
  • One-piece magnetic USB storage
This clicker offers a good balance of functionality and affordability. Its slim design makes it easy to carry, while the magnetic USB storage helps prevent loss of the receiver.
Price: $6.79
AMERTEER Bluetooth Wireless Presentation Remote (Best Finger Ring Design)
For a unique and hands-free experience, the AMERTEER ring-style clicker is worth considering.
Key Features:
  • Ring design for hands-free operation
  • Adjustable size
  • Five-button control area
  • Red laser pointer
  • 39-foot control range
This innovative design allows you to wear the clicker on your finger, providing easy access to controls without needing to hold a separate device.
Price: $18.99
AMERTEER Wireless Presentation Clicker (Best Ergonomic Design)
Another offering from AMERTEER, this model focuses on ergonomic design for comfortable extended use.
Key Features:
  • Ergonomic design made from ABS plastic
  • Built-in receiver storage
  • Red laser pointer
  • 39-foot wireless range
  • Compatible with Windows, Linux, and macOS
This clicker strikes a balance between simplicity and functionality, with an emphasis on user comfort during long presentations.
Price: $11.99
Logitech R500s Laser Presentation Remote
While not as advanced as the Spotlight, the Logitech R500s offers reliable performance at a more accessible price point.
Key Features:
  • Simple three-button design
  • 65-foot wireless range
  • Dual connectivity: Bluetooth and USB
  • Compatible with Windows, macOS, Chrome OS, and Linux
  • Red laser pointer
  • 12-month battery life
The R500s focuses on simplicity and reliability, making it a solid choice for those who prefer a straightforward presentation tool.
Price: Varies (check current pricing)
Conclusion
Choosing the right PowerPoint clicker can significantly enhance your presentation delivery. Whether you prioritize advanced features, ergonomic design, or budget-friendly options, there’s a clicker on this list to suit your needs. Consider your specific requirements, such as wireless range, compatibility, and special features like air mouse control or vibration alerts, when making your decision.
Remember, the best clicker for you is one that feels comfortable and allows you to focus on engaging with your audience rather than wrestling with technology. With any of these top picks, you’ll be well-equipped to deliver impactful, professional presentations in 2025 and beyond.
