Synology Unveils CC400W: AI-Powered Wi-Fi Camera for Smart Home Security
Synology has entered the smart home security market with its latest offering - the CC400W AI-powered Wi-Fi camera. This compact device packs advanced features into a flexible, easy-to-install package designed for homes and small businesses.
Key Features of the Synology CC400W
High-Quality Video Capture
The CC400W doesn’t compromise on video quality. It captures footage at 2560x1440 resolution with a smooth 30 frames per second. The wide 125-degree field of view ensures you can monitor large areas without blind spots. For challenging lighting conditions, the camera employs High Dynamic Range (HDR) technology to balance exposure across bright and dark areas.
When the sun goes down, the CC400W switches to night vision mode. Its high-power infrared LED illuminates subjects up to 10 meters away, allowing for clear footage even in total darkness.
Flexible Installation Options
One of the CC400W’s biggest strengths is its versatility. The camera connects via dual-band Wi-Fi (2.4GHz and 5GHz), eliminating the need for complex wiring. This wireless design, combined with its compact form factor, allows for easy placement almost anywhere.
Synology provides multiple mounting options:
  • Wall mount
  • Ceiling mount
  • Magnetic surface attachment
The camera’s IP65 weather-resistant rating means it can handle both indoor and outdoor installations. However, it’s important to note that while resistant to dust and low-pressure water jets, it’s not fully waterproof. For permanent outdoor use, consider additional weather protection.
AI-Powered Smart Detection
The CC400W leverages on-device artificial intelligence to provide real-time alerts and reduce false alarms. Key AI features include:
  • People and Vehicle Detection: Accurately distinguishes humans and vehicles from other moving objects.
  • Intrusion Detection: Alerts you when people or vehicles cross predefined virtual boundaries.
  • Auto Tracking: The camera automatically follows moving subjects, keeping them centered in the frame.
  • Instant Search: Quickly locate specific events involving people, vehicles, or motion in recorded footage.
When paired with Synology’s more advanced DVA (Deep Video Analytics) systems, the CC400W can unlock even more capabilities:
  • Facial Recognition
  • License Plate Reading
  • People Counting
Efficient Storage and Bandwidth Usage
Synology has implemented several technologies to optimize storage and network usage:
  • H.265 Compression: This modern video codec significantly reduces file sizes without sacrificing quality.
  • Smart Bitrate Control: Dynamically adjusts compression based on scene complexity, further reducing bandwidth and storage needs.
  • Edge Storage: A built-in microSD card slot (supporting up to 256GB) allows for local recording, reducing network traffic and providing a backup in case of connectivity issues.
Seamless Integration with Synology Ecosystem
For users already invested in Synology’s NAS (Network Attached Storage) or surveillance products, the CC400W offers plug-and-play compatibility. It integrates directly with Synology’s Surveillance Station software and the DS cam mobile app. Importantly, the CC400W doesn’t require a separate Surveillance Station device license, making it more cost-effective to expand your camera network.
Two-Way Audio Communication
The CC400W features both a built-in microphone and speaker. This enables two-way audio, allowing you to listen in on your surroundings and communicate through the camera. This can be useful for deterring intruders or simply checking in on pets or family members.
Privacy and Security Features
In today’s connected world, security is paramount. The CC400W addresses these concerns with several key features:
  • Encrypted Transmission: Supports HTTPS and SRTP protocols for secure video and data transfer.
  • Regular Firmware Updates: Synology provides ongoing security patches to address potential vulnerabilities.
  • NDAA and TAA Compliance: Meets US government procurement regulations, indicating a high standard of security vetting.
  • Privacy Masking: Allows you to block out sensitive areas in both live and recorded footage.
Setting Up Your Synology CC400W
Step 1: Choose your installation location, considering Wi-Fi signal strength, desired viewing angle, and protection from the elements if outdoors.
Step 2: Download the Synology DS cam app on your mobile device.
Step 3: Power on the CC400W and use the app to connect it to your Wi-Fi network.
Step 4: Mount the camera using your preferred method (wall, ceiling, or magnetic surface).
Step 5: Fine-tune the camera angle and settings through the DS cam app or Surveillance Station interface.
Step 6: Set up detection zones and notification preferences to customize your surveillance experience.
Maximizing Your CC400W’s Potential
  • Regularly clean the camera lens for optimal image quality.
  • Experiment with detection sensitivity settings to find the right balance between alerts and false positives.
  • If using outdoors, consider additional weather protection or positioning under eaves for longevity.
  • Utilize the two-way audio feature for both security (deterring intruders) and convenience (communicating with family).
  • Explore advanced AI features if pairing with Synology’s DVA systems for more comprehensive surveillance analytics.
The Synology CC400W represents a significant step into the smart home security market for the company. By combining high-quality video, AI-powered detection, and seamless integration with their existing ecosystem, Synology has created a compelling option for both home users and small businesses looking to upgrade their surveillance capabilities.
