Hey everyone, I wanted to share a cool trick to make using ChatGPT even easier. Instead of heading to the website or using a separate app, you can set ChatGPT as your default search engine in Firefox! Here’s how to do it.
Method 1: Adding ChatGPT as a Search Engine
This method lets you directly integrate ChatGPT into your Firefox search bar.
- Open Firefox and type
about:config
in the address bar, then hit Enter.
- You’ll see a warning page. Click “Accept the Risk and Continue” to proceed.
- In the search bar at the top, type
browser.urlbar.update2.engineAliasRefresh
. Make sure the value is set to “True”. If not, toggle the setting to true.
- Go to the Firefox homepage and click the hamburger menu (three horizontal lines) in the top right corner.
- Select “Settings” from the dropdown menu.
- In the left sidebar, click on “Search”.
- Scroll down to the “Search Shortcuts” section and click the “Add” button.
- A window will appear to add the search engine. Enter a name (like “ChatGPT”) in the “Name” field. Then, in the “URL” field, paste this:
https://chatgpt.com/?q=%s&hints=search
. Type@ChatGPT
in the “Alias” field. Click “Add Engine”.
- Scroll back up to the “Default Search Engine” dropdown menu and select “ChatGPT”.
- Now, whenever you type a search query in the address bar, Firefox will use ChatGPT to provide the results.
Android Instructions
Here’s how to set it up on your Android phone:
- Open Firefox on Android and tap the three dots in the top right corner.
- Tap “Settings”.
- On the Settings page, tap “Search”.
- Tap “Default search engine”.
- Tap “+ Add search engine”.
- Enter
ChatGPT
in the Name field andhttps://chatgpt.com/?q=%s&hints=search
in the URL field, then tap “Save”.
- On the “Default Search Engine” page, tap “ChatGPT” to set it as default.
- Now, Firefox on your Android device will use ChatGPT for all your searches!
Things to keep in mind
- The steps are similar for other Chromium-based browsers such as Opera, Arc, and Brave.
- You can use a browser extension like ChatGPT Search if the above methods don’t work for you.
- If you face issues while using ChatGPT, verify the URL, and check your internet connection.
- You can always switch back to a different search engine via the settings page.
