Samsung's New UWB Chip Brings Advanced Positioning to Vehicles
Samsung has unveiled its latest Ultra-Wideband (UWB) chip designed specifically for automotive applications - the Exynos Auto UA200. This new chip represents a significant advancement in vehicle positioning and connectivity technology, offering enhanced capabilities over its predecessor, the UA100.
Key Features of the Exynos Auto UA200
The Exynos Auto UA200 brings several notable improvements to in-vehicle UWB technology:
Centimeter-Level Accuracy
One of the UA200’s standout features is its ability to measure distances with centimeter-level precision. This high degree of accuracy enables a range of advanced automotive applications, from keyless entry systems to precise indoor navigation.
Enhanced Security
Security is paramount in automotive systems, and the UA200 addresses this with advanced encryption methods. The chip utilizes Scrambled Timestamp Sequence (STS) technology to encrypt time data within signals, providing robust protection against potential security threats.
Expanded Channel Support
While its predecessor, the UA100, featured two channels, the UA200 expands this to six channels. This increase allows for more simultaneous connections and improved performance in complex environments with multiple UWB devices.
Integrated Microcontroller
The UA200 incorporates a built-in tri-core Cortex-M33 microcontroller. This integration allows for on-chip processing of UWB data, potentially reducing latency and improving overall system efficiency.
Applications in Modern Vehicles
The capabilities of the Exynos Auto UA200 open up several exciting possibilities for automotive applications:
Precise Keyless Entry
UWB technology allows vehicles to precisely locate a key fob or smartphone, enabling secure and convenient keyless entry systems. The UA200’s centimeter-level accuracy ensures that these systems can reliably determine when an authorized user is approaching the vehicle.
Child Presence Detection
In response to new European regulations set to take effect in 2025, the UA200 supports Child Presence Detection (CPD) systems. When combined with in-vehicle radar technology, the chip can help detect the presence of children or pets left in a vehicle, potentially preventing tragic incidents.
Driver Monitoring
The UA200 can work in conjunction with radar systems to monitor a driver’s respiratory rate. This capability could be used in advanced driver assistance systems (ADAS) to detect signs of drowsiness or other health issues that might affect driving safety.
Indoor Navigation
The high accuracy of UWB positioning makes it ideal for indoor environments where GPS signals may be unreliable. This could enable precise navigation within parking structures or other enclosed spaces.
Technical Specifications
The Exynos Auto UA200 comes equipped with:
  • 416KB of SRAM
  • 2MB of eFlash storage
  • A built-in Power Management Unit (PMU)
  • RF and baseband processing blocks
These specifications allow the chip to handle complex UWB operations while maintaining low power consumption, an important consideration in automotive applications.
Industry Impact and Future Outlook
Samsung’s introduction of the Exynos Auto UA200 comes at a time when the automotive industry is increasingly embracing UWB technology. The chip’s advanced features position it as a competitive offering in this growing market.
As vehicles become more connected and autonomous, precise positioning technologies like UWB are likely to play an increasingly important role. The UA200’s combination of accuracy, security, and integrated processing capabilities make it well-suited to meet the demands of next-generation automotive systems.
The Exynos Auto UA200 represents a significant step forward in automotive UWB technology. As car manufacturers continue to innovate and integrate new features, chips like the UA200 will be crucial in enabling the connected, secure, and intelligent vehicles of the future.
