Samsung's New AI-Powered Washer-Dryer Combo Brings Smart Home Integration to Laundry
Samsung has unveiled its latest innovation in home appliances - the Bespoke AI Laundry Combo, an all-in-one washer-dryer unit that aims to revolutionize the laundry experience through artificial intelligence and smart home integration.
Key Features of the Bespoke AI Laundry Combo
AI-Powered Washing and Drying
The centerpiece of Samsung’s new laundry system is its AI OptiWash and AI Dry technology. These intelligent systems use sensors to detect the weight, fabric type, and soil level of each load. The washer then automatically adjusts water levels, detergent amounts, and cycle settings for optimal cleaning. Similarly, the dryer customizes temperature and drying time based on the load characteristics.
Large Capacity in a Space-Saving Design
Despite its all-in-one design, the Bespoke AI Laundry Combo boasts an impressive 5.3 cubic foot capacity. This allows it to handle large loads, including bulky items like comforters, while still fitting into spaces where separate units may not be practical.
Super Speed Cycle
For those times when clean clothes are needed quickly, the Super Speed cycle can wash and dry a full load in just 98 minutes. This rapid turnaround time is achieved without compromising cleaning quality.
A standout feature is the 7-inch AI Home touchscreen display integrated into the unit. This interface serves as a control center not just for the washer-dryer, but potentially for your entire smart home ecosystem.
Advancing the “Screens Everywhere” Vision
The inclusion of the AI Home display on the Bespoke AI Laundry Combo is part of Samsung’s broader “Screens Everywhere” initiative first introduced at CES 2025. This strategy aims to incorporate smart displays into various household appliances, turning them into hubs for home automation and entertainment.
Multi-Functional Display
Beyond controlling laundry cycles, the AI Home display allows users to:
  • Monitor detergent levels and receive low-supply alerts
  • Control other SmartThings-compatible devices in the home
  • Stream video content from services like YouTube
  • Play music while doing laundry
AI-Driven Convenience
Samsung has designed the Bespoke AI Laundry Combo to simplify laundry routines through machine learning and predictive features.
Learned Preferences
The system learns from your washing and drying habits over time. It can then suggest your most frequently used cycles or settings, streamlining the process of starting a load.
Flex Auto Dispense System
This intelligent detergent management system can hold enough detergent for up to 47 loads. It automatically dispenses the correct amount based on load size and soil level, eliminating the need to measure detergent for each wash.
Energy Efficiency and Sustainability
The Bespoke AI Laundry Combo incorporates several features aimed at reducing energy consumption and environmental impact:
  • Heat pump technology in the dryer uses significantly less energy than traditional heating elements
  • AI Energy mode optimizes cycles to reduce power usage by up to 70%
  • Less Microfiber cycle option reduces microplastic shedding by up to 54% when washing synthetic fabrics
Availability and Options
Samsung is rolling out the Bespoke AI Laundry Combo in various markets worldwide. The system is available in both large (5.3 cu. ft.) and smaller capacities to suit different household needs. Additionally, consumers can choose between heat pump and vented dryer options depending on their home setup and local regulations.
The Bespoke AI Laundry Combo represents a significant step forward in laundry technology, merging advanced cleaning capabilities with smart home functionality. As these AI-driven appliances become more prevalent, they have the potential to transform daily chores into more efficient, customized experiences.
