Raw Accel for VALORANT: Optimizing Mouse Acceleration Settings
Raw Accel has become a popular tool among VALORANT players looking to fine-tune their mouse acceleration for improved aim and performance. This third-party software allows users to create custom mouse acceleration curves, potentially enhancing precision and responsiveness in-game. Let’s explore how to set up and optimize Raw Accel for VALORANT.
What is Raw Accel?
Raw Accel is an open-source mouse acceleration program that gives users granular control over their mouse movement. Unlike built-in Windows mouse acceleration, Raw Accel allows for custom acceleration curves and settings. For VALORANT players, this can translate to more precise aiming, especially when switching between small adjustments and quick flicks.
Setting Up Raw Accel for VALORANT
To get started with Raw Accel:
Step 1: Download the latest version of Raw Accel from the official GitHub repository.
Step 2: Extract the files and run the installer.
Step 3: Open the Raw Accel GUI after installation.
Step 4: In the “Charts” tab, input your mouse DPI and polling rate (typically 1000Hz for gaming mice).
Step 5: Choose an acceleration type from the dropdown menu. “Linear” or “Natural” are good starting points for VALORANT.
Optimizing Raw Accel Settings
While personal preference plays a significant role, here are some guidelines to help you find optimal settings:
Sensitivity Multiplier
Start with a sensitivity multiplier of 1.0 and adjust based on how it feels in-game. Increase for more acceleration or decrease for a more gradual curve.
Acceleration
Begin with a low acceleration value (e.g., 0.05) and incrementally adjust. Higher values result in more pronounced acceleration.
Cap Type and Output
Set the cap type to “Output” and start with a cap output of 1.2-1.5. This limits the maximum acceleration to prevent overshooting targets.
Input Offset
An input offset of 10-15 can help maintain precision for small movements while allowing acceleration for faster swipes.
Pro Player Settings: TenZ’s Configuration
Tyson “TenZ” Ngo, a professional VALORANT player known for his aim, uses the following Raw Accel settings:
  • Sensitivity Multiplier: 1.0
  • Acceleration Type: Linear
  • Acceleration: 0.05
  • Cap Type: Output
  • Cap Output: 1.2
  • Input Offset: 15
TenZ pairs these Raw Accel settings with an in-game sensitivity of 0.16 at 1600 DPI. However, remember that these settings are personalized and may not work for everyone.
Fine-Tuning Your Settings
To find your ideal settings:
Step 1: Start with TenZ’s settings or the recommended baseline.
Step 2: Use VALORANT’s practice range or a third-party aim trainer to test different configurations.
Step 3: Pay attention to how comfortable you feel with micro-adjustments and flicks.
Step 4: Gradually adjust one parameter at a time, noting the changes in your aim and comfort.
Step 5: Once you find a comfortable setup, stick with it for at least a week before making further adjustments.
Raw Accel Curve Helper
For those who want a more data-driven approach, the Raw Accel Curve Helper spreadsheet can be a valuable tool. This community-created resource helps calculate optimal sensitivity multipliers based on your current settings and desired acceleration curve.
Is Raw Accel Allowed in VALORANT?
As of now, Riot Games has not explicitly banned the use of Raw Accel in VALORANT. However, as with any third-party software, there’s always a small risk of false positives in anti-cheat systems. Use Raw Accel at your own discretion, and stay updated on Riot’s stance on such tools.
Raw Accel offers VALORANT players a new level of customization for mouse acceleration. While it can take time to find the perfect settings, many users report improved aim consistency and comfort after proper configuration. Remember, the best settings are those that feel natural to you, so don’t be afraid to experiment and fine-tune your setup.
