Quick Guide to Finding and Handling Duplicates in Google Sheets
Having duplicate data in your Google Sheets can really mess things up, making your spreadsheets confusing and inaccurate. It’s super important to spot and deal with these duplicates to keep your data clean and your analysis on point.
Method 1: Removing Duplicate Data
If you need to get rid of those duplicate entries altogether, Google Sheets has a built-in tool that makes it fast and easy. This is the most efficient way to clean up your data without having to manually delete each duplicate row or cell.
  1. First, select the entire data range where you want to remove any duplicates.
  2. Next, click on the “Data” menu at the top and then choose “Remove duplicates” from the dropdown list.
  3. In the dialog box that pops up, select the columns you want to check for duplicates. You can select “Select all” to look at entire rows or pick specific columns to check for duplicates only in those columns.
  4. Click “Remove duplicates” at the bottom of the dialog. Google Sheets will then process the data, and let you know how many duplicate rows were removed and how many unique rows you now have left.
  5. Click “OK” to close the dialog box. Your spreadsheet is now free of duplicates in the chosen range.
Method 2: Highlighting Entire Rows with Duplicate Data
When you’re working with a large spreadsheet that has related data across many columns, it’s often useful to highlight entire rows that have duplicate entries in a specific column. This is really helpful to make sure that you don’t miss any duplicates, even if the duplicate cell isn’t right in front of you.
  1. First, select all the cells in your sheet where you want the formatting to apply.
  2. Then, click on “Format” in the menu at the top, and choose “Conditional formatting.”
  3. In the Conditional Formatting sidebar that appears on the right, delete any formatting rules you might already have, then click on “Add another rule” at the bottom.
  4. Double-check that the “Apply to range” field shows the correct cells you selected. Under “Format cells if,” choose “Custom formula is” from the dropdown menu.
  5. Enter the following formula into the text box:
    =countif($A$2:$A$9,$A2)>1
  6. This formula checks column A for duplicates. The $ symbols make sure that the formula always refers to the correct column and rows.
  7. Choose a formatting style for the duplicates, like a fill color, in the “Formatting style” section. Click “Done” to apply the rule.
  8. Now, the entire rows with duplicate entries in column A are highlighted, making them easy to find.
  9. Remember, you can change the formula to check other columns by replacing $A$2:$A$9 and $A2 with the correct column references.
Method 3: Highlighting Duplicate Cells in a Column
If you just want to highlight the duplicate cells within a column, you can also use conditional formatting. This way is useful when you’re only concerned with highlighting the duplicates in one column, without marking entire rows.
  1. Select the range of cells within the column where you want to identify duplicates.
  2. Go to the “Format” menu at the top, and then click on “Conditional formatting.”
  3. In the Conditional Formatting pane, check that the “Apply to range” field contains the right cells you’ve just selected. Then, under “Format cells if,” select “Custom formula is” from the dropdown.
  4. Type the following formula into the text box:
    =countif($A$2:$A$9,A2)>1
  5. This formula counts how many times each value appears in the selected range and highlights cells where the count is more than one.
  6. Pick a formatting style to highlight the duplicate cells, like a fill color. Click “Done” to apply this conditional formatting rule.
  7. The duplicate cells within your column should now be highlighted.
By using these methods to highlight or remove duplicates, you can ensure your data is clean and accurate. These techniques save a lot of time and help reduce mistakes, allowing you to focus on the unique data you have.
