Managing disk partitions is a crucial task for Linux system administrators. The fdisk
command is a powerful command-line tool that enables you to create, modify, and delete partitions on your Linux system. In this guide, we’ll walk through the process of creating partitions using fdisk
step by step. We’ll attach a 10 GB raw disk to our Linux system and create two partitions on it.
Prerequisites
Before you begin, make sure you have the following:
A running Linux system.
Root privileges or a
sudo
user with administrative rights. -
Basic understanding of disks and partitions: Familiarize yourself with device naming conventions in Linux, such as
/dev/sda
,/dev/sdb
, and/dev/nvme0n1
Steps to Create Partitions in Linux Using fdisk
Method 1: Using fdisk
Step 1: Identify the disk.
First, identify the newly attached raw disk on which you want to create partitions.
Run the fdisk -l
command and look for unpartitioned/unallocated drives.
$ sudo fdisk -l
Alternatively, you can verify the disk (e.g., /dev/sdb
) by running the command:
$ lsblk
Step 2: Run fdisk
for the target disk.
Run the fdisk
command with the target disk as an argument:
$ sudo fdisk /dev/sdb
Once inside the fdisk
interactive menu, you will see a prompt like this:
Command (m for help):
Note: Type m
and press Enter to display a list of available commands.
Step 3: Create a new partition.
To create a new partition, type n
and press Enter. You will be prompted to select the partition type and number.
Select Partition Type:
p
for primary partition -
e
for extended partition
Specify the Partition Number: If it’s the first partition, type 1
and press Enter.
Set the Start and End Sectors:
Press Enter to accept the default starting sector.
Specify the size by entering a value (e.g.,
+4G
for a 4 GB partition).
Create two partitions, each of size 4 GB.
Step 4: Write the changes.
After defining the partitions, type w
and press Enter to write the changes to the disk. This step finalizes the partitioning.
Step 5: Verify the new partitions.
Run the following command to verify the new partitions on disk /dev/sdb
$ sudo fdisk -l /dev/sdb
You should see two new partitions listed, such as /dev/sdb1
and /dev/sdb2
with their respective IDs and types.
Step 6: Format partitions with mkfs
Format the newly created partitions with a file system. For example, to format /dev/sdb1
as ext4
and /dev/sdb2
as xfs
, run the following commands:
$ sudo mkfs.ext4 /dev/sdb1
$ sudo mkfs.xfs /dev/sdb2
The output will confirm that both partitions have been formatted with the ext4
and xfs
file systems, respectively.
Step 7: Mount the partitions.
To mount these partitions, first create mount points:
$ sudo mkdir /opt/data1
$ sudo mkdir /opt/data2
Now, run the mount
command:
$ sudo mount /dev/sdb1 /opt/data1
$ sudo mount /dev/sdb2 /opt/data2
Next, run the df
command to verify whether the new partitions are mounted:
$ df -Th
To mount these disk partitions permanently, add the following entries to the /etc/fstab
file:
/dev/sdb1 /opt/data1 ext4 defaults 0 0
/dev/sdb2 /opt/data2 xfs defaults 0 0
Save and close the file, and then run:
$ sudo mount -a
Troubleshooting Common Issues
Partition Not Showing Up
If the new partition doesn’t appear, run the following command to reload the partition table:
$ sudo partprobe
Unable to Format the Partition
Ensure the partition is not mounted before formatting. Use:
$ sudo umount /dev/sdb1
The fdisk
command is a versatile tool for managing disk partitions in Linux. By following this guide, you can confidently create partitions and prepare them for use.
