Monitor and check VRAM usage in Windows 11
VRAM (Video Random Access Memory) plays a crucial role in managing graphics tasks on your PC. This dedicated memory stores graphics data and textures needed for smooth operation of games, video editing software, and other visual applications. Monitoring VRAM usage helps optimize performance and prevent graphics-related slowdowns.
What VRAM does
VRAM functions as a specialized memory bank directly on your graphics card, storing visual data for quick GPU access. More VRAM means better handling of high-resolution textures and complex graphics. Desktop PCs allow VRAM upgrades through graphics card replacement, while laptop VRAM is typically fixed to the motherboard. Many modern laptops combine integrated and discrete GPUs for balanced performance.
Task manager method
The built-in Task Manager offers real-time VRAM monitoring without extra software installation.
  1. Access Task Manager with Ctrl+Shift+Esc or right-click the Start button and select ‘Task Manager’
  1. Navigate to the ‘Performance’ tab in the left sidebar
  1. Click ‘GPU’ to view VRAM usage stats and temperature data
GPU Shark method
For detailed VRAM analysis, GPU Shark provides comprehensive monitoring capabilities.
  1. Get GPU Shark from www.geeks3d.com/645
  1. Extract the downloaded .ZIP file
  1. Run gpushark.exe (click ‘Run’ if prompted)
  1. View detailed GPU metrics including VRAM usage
Windows settings method
Access basic VRAM information through Windows Settings:
  1. Open Settings with Windows+I or through Start menu
  1. Select ‘System’ from the sidebar
  1. Click ‘Display’
  1. Select ‘Advanced display’
  1. Click ‘Display adapter properties for Display 1’
  1. Find VRAM amount under ‘Dedicated Video Memory’
System information tool method
  1. Press Windows+R, type msinfo32, hit Enter
  1. Expand ‘Components’ and select ‘Display’
  1. Review graphics hardware details
DirectX diagnostic tool method
  1. Press Windows+R, type dxdiag, press Enter
  1. Select ‘Display’ tab for primary GPU info
  1. Check ‘Render’ tab for additional GPUs
