Make a Windows 11 recovery USB drive for system backup
A recovery USB drive acts as a safety net when your Windows 11 system encounters critical problems. This backup solution helps restore your computer’s functionality without requiring a full Windows reinstallation.
Before starting, remember that a recovery drive stores only Windows system files and built-in applications - not your personal data or installed programs. The recommended practice is to make a fresh recovery drive once every year to include the latest system updates.
Required: A USB drive with minimum 16GB storage (32GB recommended)
Create recovery drive through control panel
The control panel method offers the most reliable way to create a recovery drive, with a straightforward process that works consistently across all Windows 11 versions.
  1. Press the Windows key, type Control in the search box, and select Control Panel from the results.
  1. Switch the view mode to Large icons or Small icons, then locate and click Recovery.
  1. Select Create a recovery drive from the available options.
  1. When prompted by User Account Control, click Yes to proceed.
  1. Enable the Back up system files to the recovery drive option and click Next.
  1. Choose your USB drive from the list and click Next.
  1. Acknowledge the warning about data deletion and click Create to begin the process.
Using your recovery drive
When Windows fails to start normally, your recovery drive provides access to system repair tools.
  1. Insert the USB drive and restart your PC. Access the boot menu by pressing the appropriate key (F12, F2, Del, or Esc).
  1. Select your USB drive from the boot device list and press Enter.
  2. In the recovery environment, click Recover from a drive.
  1. Select either Just remove my files for a quick reset or Fully clean the drive for complete data erasure.
  1. Review the recovery details and click Recover to start the restoration process.
The recovery process will reset Windows to its original state. After completion, you can restore your personal files from your backup storage.
