Are you looking to install Jenkins on a Kubernetes cluster? This guide provides a detailed walkthrough using YAML manifest files, offering direct control and customization over your Jenkins deployment. This approach enhances visibility into the deployment process.
Prerequisites
Before starting, make sure you have the following:
A running Kubernetes cluster (local or cloud-based).
kubectl
CLI tool installed and configured. -
Basic understanding of Kubernetes concepts.
Cluster administrator privileges.
Installing Jenkins with YAML Manifests
Step 1: Create a Namespace for Jenkins
First, create a dedicated namespace to organize Jenkins resources:
kubectl create namespace jenkins
Step 2: Create a Service Account and RBAC Configuration
Jenkins requires specific permissions to interact with the Kubernetes cluster. Set up the necessary RBAC configuration by creating a jenkins-sa.yaml
file:
apiVersion: rbac.authorization.k8s.io/v1
kind: ClusterRole
metadata:
rules:
- apiGroups: [""]
resources: ["*"]
verbs: ["*"]
apiVersion: v1
kind: ServiceAccount
metadata:
namespace: jenkins
kind: ClusterRoleBinding
metadata:
roleRef:
apiGroup: rbac.authorization.k8s.io
kind: ClusterRole
subjects:
- kind: ServiceAccount
namespace: jenkins
Step 3: Apply the RBAC Configuration
Apply the jenkins-sa.yaml
file using:
kubectl apply -f jenkins-sa.yaml
Step 4: Create Persistent Volume
Jenkins needs persistent storage for its data. Create a PV and PVC using the following jenkins-volume.yaml
file:
kind: StorageClass
apiVersion: storage.k8s.io/v1
metadata:
provisioner: kubernetes.io/no-provisioner
volumeBindingMode: WaitForFirstConsumer
apiVersion: v1
kind: PersistentVolume
metadata:
labels:
type: local
spec:
storageClassName: local-storage
claimRef:
namespace: jenkins
capacity:
storage: 30Gi
accessModes:
- ReadWriteOnce
local:
path: /mnt
nodeAffinity:
required:
nodeSelectorTerms:
- matchExpressions:
- key: kubernetes.io/hostname
operator: In
values:
- worker01
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
namespace: jenkins
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 20Gi
Step 5: Apply the Volume Configuration
Apply the jenkins-volume.yaml
file using:
kubectl apply -f jenkins-volume.yaml
Step 6: Verify PV and PVC Status
Verify the status of PV and PVC using:
kubectl get pv,pvc -n jenkins
Step 7: Install Jenkins on Kubernetes Cluster
Create the Jenkins deployment manifest file (jenkins-deployment.yaml
) with these configurations:
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: jenkins
spec:
replicas: 1
selector:
matchLabels:
app: jenkins-server
template:
metadata:
labels:
app: jenkins-server
spec:
securityContext:
fsGroup: 1000
runAsUser: 1000
serviceAccountName: jenkins-admin
containers:
- name: jenkins
image: jenkins/jenkins:lts
resources:
limits:
memory: "2Gi"
cpu: "2"
requests:
memory: "1Gi"
cpu: "1"
ports:
- name: web-port
containerPort: 8080
- name: agent-port
containerPort: 50000
livenessProbe:
httpGet:
path: "/login"
port: 8080
initialDelaySeconds: 90
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 5
readinessProbe:
httpGet:
path: "/login"
port: 8080
initialDelaySeconds: 60
periodSeconds: 10
timeoutSeconds: 5
failureThreshold: 3
volumeMounts:
- name: jenkins-data
mountPath: /var/jenkins_home
volumes:
persistentVolumeClaim:
claimName: jenkins-pv-claim
Step 8: Apply the Jenkins Deployment
Apply the jenkins-deployment.yaml
file:
kubectl apply -f jenkins-deployment.yaml
Step 9: Verify Deployment and Pod Status
Verify the status of the deployment and pods:
kubectl get deployment -n jenkins
kubectl get pods -n jenkins
Step 10: Create Jenkins Service
Expose the Jenkins deployment using a NodePort
service. Create a jenkins-service.yaml
file:
apiVersion: v1
kind: Service
metadata:
namespace: jenkins
annotations:
prometheus.io/scrape: 'true'
prometheus.io/path: /
prometheus.io/port: '8080'
spec:
selector:
app: jenkins-server
type: NodePort
ports:
- port: 8080
targetPort: 8080
nodePort: 32000
Step 11: Apply the Jenkins Service
Apply the jenkins-service.yaml
file:
kubectl apply -f jenkins-service.yaml
Step 12: Access Jenkins Web UI
Access the Jenkins dashboard by navigating to any worker node IP on port 32000
http://<worker-node-ip>:32000
Step 13: Retrieve Initial Admin Password
On the first login, Jenkins will prompt for the initial Admin password. Get the pod name and then execute the command in the pod:
kubectl exec -it <Jenkins-pod-name> cat /var/jenkins_home/secrets/initialAdminPassword -n Jenkins
Step 14: Enter Admin Password and Configure Jenkins
Copy the password and paste it in the administrator password
field, then click Continue
. Choose Install suggested plugins
. Create your first admin user as per your setup, then click on Save and Continue
Step 15: Confirm Jenkins URL
Confirm your Jenkins URL, which is the worker node IP and node port (32000
). Click on Save and Finish
, then click on Start using Jenkins
Step 16: Test Jenkins Installation
To test the Jenkins installation, create a demo job to execute a shell command.
Installing Jenkins with Helm
Helm is a popular package manager for Kubernetes, simplifying the deployment and management of applications. Here’s how you can use Helm to install Jenkins:
Step 1: Add the Jenkins Helm Repository
Add the Jenkins Helm repository to your local Helm client:
helm repo add jenkins https://charts.jenkins.io
helm repo update
Step 2: Install Jenkins Using Helm
Install Jenkins using the Helm chart:
helm install jenkins jenkins/jenkins -n jenkins
Step 3: Access Jenkins Web UI
After installation, follow the Helm chart’s instructions to access the Jenkins web UI, usually involving port forwarding or exposing a service.
With these steps, you should have a fully functional Jenkins instance running on your Kubernetes cluster. Feel free to adapt these instructions to fit your specific environment and needs.
