Installing and Using Genymotion Android Emulator on Ubuntu
Genymotion is a powerful Android emulator that allows developers and testers to simulate Android devices on their computers. It provides a virtual environment for testing applications, games, and other software without the need for physical devices. This article will guide you through the process of installing and using Genymotion Desktop on Ubuntu 24.04.
Prerequisites
Before beginning the installation process, ensure that your system meets the following requirements:
  • Ubuntu 24.04 LTS (or later version)
  • A stable internet connection
  • At least 2 GB of free hard drive space for Genymotion (plus additional space for virtual devices)
  • CPU with virtualization support (Intel VT-x or AMD-V)
  • A Genymotion account (free signup available on the Genymotion website)
Installing Genymotion on Ubuntu
Step 1: Update your system
sudo apt update
sudo apt upgrade -y
Step 2: Download the Genymotion installer
Visit the official Genymotion download page or use the following command to download the latest version:
wget https://dl.genymotion.com/releases/genymotion-3.8.0/genymotion-3.8.0-linux_x64.bin
Step 3: Make the installer executable
chmod +x genymotion-3.8.0-linux_x64.bin
Step 4: Run the installer
./genymotion-3.8.0-linux_x64.bin
Follow the prompts to complete the installation. You can accept the default installation directory or specify a custom path.
Getting Started with Genymotion
Step 1: Launch Genymotion
You can start Genymotion from the application menu or by running the following commands in the terminal:
cd ~/genymotion
./genymotion
Step 2: Log in to your Genymotion account
When you open Genymotion for the first time, you’ll be prompted to log in with your Genymotion account.
Step 3: Create a virtual device
  • Click on the “Add” button to create a new device
  • Select the Android version and device model you want to emulate
  • Click “Next” and follow the prompts to complete the setup
Step 4: Start the virtual device
Once the virtual device is created, you can start it by clicking the “Play” button.
Integrating Genymotion with Android Studio
If you’re using Android Studio for development, you can integrate Genymotion for seamless app testing:
Step 1: Open Android Studio
Step 2: Go to File > Settings > Plugins
Step 3: Search for “Genymotion” and install the plugin
Step 4: Restart Android Studio and configure the plugin with your Genymotion installation path
Troubleshooting Tips
  • If the virtual device shows a black screen, ensure that virtualization is enabled in your BIOS/UEFI settings
  • For network connectivity issues, check your firewall settings and ensure Genymotion has the necessary permissions
  • Allocate more RAM and CPU resources to Genymotion in the settings for better performance
Removing Genymotion from Ubuntu
If you need to uninstall Genymotion, follow these steps:
Step 1: Delete the Genymotion installation directory
rm -rf ~/genymotion
Step 2: Remove configuration files and virtual device data
rm -rf ~/.Genymobile
rm -rf ~/.config/Genymotion
Step 3: Remove the desktop entry (if added)
rm ~/.local/share/applications/genymobile-genymotion.desktop
Step 4: Search for any remaining files
sudo find / -name "*genymotion*"
If no files are found, Genymotion has been successfully removed from your system.
Installing and using Genymotion on Ubuntu 24.04 is a straightforward process that can greatly enhance your Android development and testing workflow. By following this guide, you can set up Genymotion and start running virtual Android devices on your system in no time. Whether you’re a developer testing apps or a user exploring Android, Genymotion provides a powerful and flexible emulation experience on Ubuntu.
