Microsoft Edge, that browser from Microsoft, is built on the same base as Chrome (Chromium). You’ll find it comes pre-installed on every Windows PC. Microsoft has taken its time, but now Edge is finally a serious contender with other big-name browsers.
One of the great things about Edge is that it’s now available on multiple platforms. This is super handy for anyone switching from Windows or Android to macOS or iOS. It’s also a solid option if you’re looking for an alternative to Safari on your Apple devices.
If you’re making a platform switch and want a smooth transition or just want to try something other than Safari, this guide is for you.
So, let’s get right into how to install Microsoft Edge on your iPhone and Mac.
Installing Microsoft Edge on your iPhone
Downloading and installing apps from the App Store on your iPhone is pretty straightforward. Microsoft Edge is no different. Just remember that any extensions you use on your computer version of Edge won’t be available on the mobile app.
First, open the App Store on your iPhone. You can find it either on your home screen or in your app library.
Next, tap on the “Search” tab at the bottom right of the screen.
Now, type “Microsoft Edge” in the search bar and hit the blue “search” button on your keyboard.
In the search results, find the “Microsoft Edge” app, open it, and tap the “Get” button. You’ll need to verify the download with your preferred authentication method, but don’t worry, it’s free.
Once the app is installed, you’ll find it either on your home screen or in your app library.
You can log in using your Microsoft account, and any favorites, passwords, and reading lists will be synced to your mobile app.
Installing Microsoft Edge on your MacBook
Installing Edge on macOS is a bit different than on iOS, but it’s not a difficult process.
To get Edge on your Mac, go to microsoft.com/edge using your browser of choice. Then click on the “Download for macOS” button. A window will pop up.
Select the correct option for your Mac: “Mac with Intel chip” or “Mac with Apple chip” if you’ve got an M1 or later.
Click “Accept & download” to start the download.
Once it’s downloaded, find the .PKG file in your downloads folder and double-click to start the installer.
If you get a warning that it can’t open because it’s not from Apple, click “OK” to dismiss it.
Open the “System Preferences” app. You can find it in the dock or launchpad.
Click on “Security & Privacy.”
Click the “Open Anyway” button at the bottom right to run the installer.
In the installer window, click “Continue.”
Select the disk where you want to install Edge and click “Continue.”
Finally, click the “Install” button.
Enter your device passcode and click “Install Software.”
Once it’s done, click “Close.”
A prompt will ask if you want to delete the installer. Click “Move to Trash.”
And that’s all there is to it. You’re good to go!
With recent improvements, Edge is a great browser. Installing it on your Apple devices is straightforward. Enjoy browsing the internet with your newly installed browser.
