HOZO's M-Cube 02 Laser Level Brings Hands-Free Precision to Construction Projects
HOZO Design has officially launched its innovative M-Cube 02 Anti-Gravity Laser Level for retail purchase, bringing professional-grade measurement capabilities to contractors and DIY enthusiasts alike. This compact device aims to revolutionize how leveling and measurement tasks are performed on job sites and home improvement projects.
Vacuum-Powered Wall Mounting
The standout feature of the M-Cube 02 is its vacuum adhesion system that allows it to securely attach to walls and other surfaces without additional support. This hands-free operation eliminates the need for tripods or manual holding, enabling users to focus on their work.
Step 1: Place the M-Cube 02 against a clean, flat surface.
Step 2: Press the power button to activate the vacuum pump.
Step 3: Wait for the device to indicate a secure seal has been achieved.
The vacuum system can maintain suction up to 55,000 PA, with built-in pressure monitoring to ensure it stays firmly in place. If the pressure drops below a safe threshold, the pump automatically reactivates to maintain adhesion.
Versatile Measurement Capabilities
Beyond its unique mounting system, the M-Cube 02 combines multiple measurement tools into a single device:
Laser Leveling
The unit projects both horizontal and vertical laser lines for precise alignment. Its 360-degree rotation capability allows for easy adjustments without remounting.
Distance Measurement
An integrated laser distance meter can measure up to 131 feet (40 meters) with accuracy to within 1/16 inch (2mm).
Angle Detection
The built-in angle sensor provides real-time feedback on the device’s orientation, allowing for precise angle measurements and adjustments.
Smart Features for Improved Workflow
HOZO has incorporated several intelligent functions to streamline common measurement tasks:
  • Midpoint Detection - Automatically calculates the center point between two measured locations.
  • MEAZOR App Integration - Syncs measurements wirelessly to a smartphone app for easy recording and sharing.
  • Customizable Units - Switch between metric and imperial measurements as needed.
Modular Ecosystem
The M-Cube 02 is designed to work with HOZO’s existing M-Cube modules, allowing users to expand its capabilities:
Available M-Cube Modules:
- 00G Green Laser Edition (for improved visibility)
- Smart Planner (for rapid room mapping)
- Scale Roller (for curved surface measurements)
This modularity provides flexibility for different job requirements without needing to purchase entirely new tools.
Durability for Job Site Conditions
Recognizing the demanding environments in which it will be used, HOZO has built the M-Cube 02 to withstand the rigors of construction sites:
  • IP54 dust and water resistance rating
  • Rubberized impact-resistant corners
  • Scratch-resistant glass for the laser aperture
Optional protective cases are available for added durability during transport and storage.
Pricing and Availability
The M-Cube 02 is now available directly from HOZO Design’s website, with Amazon listings expected soon in the US and UK markets. Pricing options include:
  • M-Cube 02 Anti-Gravity Laser Level (Base Unit): $149 / £149
  • M-Cube 02 Laser Level Pro with Green Laser Measure: $259 / £259
  • M-Cube 02 Laser Level Premium Combo (includes additional modules): $309 / £246
The M-Cube 02 represents a significant leap forward in portable laser measurement technology. Its vacuum mounting system and versatile feature set offer a compelling solution for those seeking to improve accuracy and efficiency in their construction or renovation projects.
