How to Verify and Boost Your Internet Speed
Internet speed issues can be frustrating, especially when you’re not getting the speeds you’re paying for. This guide will walk you through the process of verifying your actual internet speed and taking steps to improve it if needed.
Check Your Actual Internet Speed
The first step is to accurately measure your current internet speed:
Step 1: Connect your computer directly to your modem using an Ethernet cable. This eliminates potential WiFi interference.
Step 2: Close all programs and browser tabs that might be using your internet connection.
Step 3: Visit a reputable speed test website like Speedtest.net or Fast.com.
Step 4: Run the speed test multiple times at different hours of the day to get an average.
Step 5: Compare your results to the speed tier you’re paying for from your Internet Service Provider (ISP).
Note: Speed test results can vary based on factors like network congestion and server location. Running multiple tests provides a more accurate picture.
Understand Your Speed Plan
Before assuming there’s an issue, verify what speeds you’re actually supposed to be getting:
  • Check your ISP bill or online account for your current plan details.
  • Look for terms like “up to” in speed descriptions - this means the advertised speed is a maximum, not a guarantee.
  • Be aware of the difference between Mbps (megabits per second) and MBps (megabytes per second). 1 MBps = 8 Mbps.
Troubleshoot Common Speed Issues
If your speeds are consistently lower than expected, try these fixes:
1. Restart Your Equipment
Step 1: Unplug your modem and router from power.
Step 2: Wait 60 seconds.
Step 3: Plug the modem back in and wait for it to fully reboot.
Step 4: Plug the router back in and wait for it to reconnect.
This process can often resolve temporary connectivity issues.
2. Check for WiFi Interference
  • Move your router away from other electronic devices.
  • Try changing your WiFi channel in your router settings.
  • Consider using the 5 GHz band if your router supports it, as it’s often less congested.
3. Update Router Firmware
Outdated router firmware can impact performance. Check your router manufacturer’s website for the latest firmware version and update instructions.
4. Optimize Your Computer
  • Run a malware scan to check for bandwidth-hogging malware.
  • Update your network drivers to ensure compatibility and performance.
  • Clear your browser cache and disable unnecessary browser extensions.
Advanced Troubleshooting
If basic troubleshooting doesn’t help, try these more advanced steps:
1. Check Your Wiring
Damaged or outdated coaxial cables can significantly impact internet speeds. Inspect your cables for visible damage and consider replacing them if they’re old.
2. Use a Wired Connection
WiFi is convenient but can be slower than a wired Ethernet connection. For the best speeds, especially for bandwidth-intensive tasks, connect directly to your router with an Ethernet cable.
3. Monitor Your Network Usage
Use your router’s built-in tools or third-party software to monitor which devices are using the most bandwidth. You might discover that background processes or other users are consuming your bandwidth.
4. Consider a New Router
If you’re using an older router, it might not be capable of handling your current internet speeds. Look for routers that support the latest WiFi standards (like WiFi 6) for better performance.
When to Contact Your ISP
If you’ve tried all the above steps and are still experiencing significantly slower speeds than what you’re paying for, it’s time to contact your ISP:
Step 1: Document your speed test results, including dates and times.
Step 2: Call your ISP’s technical support.
Step 3: Explain the troubleshooting steps you’ve already taken.
Step 4: Ask them to check for any issues on their end or schedule a technician visit if needed.
Pro Tip: Some ISPs offer their own speed test tools. Using these can sometimes lead to more productive support conversations, as the ISP will have direct access to the results.
Understanding Speed Limitations
It’s important to recognize that several factors can limit your internet speed:
  • Distance from ISP infrastructure: The further you are from your ISP’s central office or node, the slower your connection might be.
  • Network congestion: During peak usage times (like evenings), speeds can slow down due to high demand.
  • Technology limitations: Some types of internet connections (like DSL) have inherent speed limitations compared to fiber or cable.
Internet speeds can be complex, but with these steps, you can ensure you’re getting the service you’re paying for. Remember, consistent communication with your ISP is key if problems persist. If you’re still not satisfied after working with your current provider, it might be worth exploring other ISPs available in your area.
