How to Troubleshoot Worker Issues in Schedule 1
The “Schedule 1” workers are crucial for expanding your drug empire, but various bugs can prevent them from functioning properly. Let’s explore some effective troubleshooting methods to get your employees back on track.
Assign Beds and Pay Workers
Workers in Schedule 1 require a designated sleeping area to function. Without an assigned bed, they’ll refuse to work even during daytime hours.
Step 1: Ensure each worker has their own bed assigned.
Step 2: Check the briefcase on each bed daily to pay your workers.
Step 3: Consider keeping extra cash in the briefcases to avoid daily micromanagement.
For larger operations, maintaining a substantial cash reserve allows for smoother worker management.
Master the Management Clipboard
The employee clipboard is a vital tool for assigning and managing workers, despite its potential complexity.
Step 1: Access the clipboard interface.
Step 2: Familiarize yourself with the various assignment options.
Step 3: Practice using the clipboard to efficiently manage your workforce.
While the clipboard system may seem unintuitive at first, mastering its use is essential for smooth operations.
Optimize Supply Routes and Storage
Proper supply management is critical, especially for specialized workers like Botanists and Handlers.
Step 1: Assign appropriate storage shelves to each worker type.
Step 2: Ensure storage shelves don’t overlap between different worker roles.
Step 3: Define clear routes for Handlers to follow when transporting goods.
Be aware that overfilled storage can cause workers to stop production. Monitor inventory levels closely to maintain productivity.
Clear Pathways and Plan Efficient Layouts
Worker pathing issues can significantly impact productivity. A well-planned layout helps prevent these problems.
Step 1: Create open spaces between work areas to prevent workers from getting stuck.
Step 2: Position related workstations and storage close together to minimize travel time.
Step 3: Regularly check for any obstacles that might be blocking worker paths.
If workers seem stuck, try reloading your save file. This often resolves pathing glitches without losing significant progress.
Stay Updated on Patches
The developers of Schedule 1 are actively addressing bugs through frequent updates.
Step 1: Enable automatic updates for the game if possible.
Step 2: Check for new patches regularly if auto-updates are disabled.
Step 3: Read patch notes to stay informed about fixed issues and new features.
Many current bugs, such as Botanists getting stuck, are likely to be resolved in upcoming patches. However, implementing the strategies above will help optimize your operation regardless of bug fixes.
While Schedule 1 continues to evolve, these troubleshooting tips should help keep your illegal empire running smoothly. Remember, a well-managed workforce is key to maximizing profits in the drug trade - virtual or otherwise!
