R.E.P.O.'s dark and treacherous environments can quickly separate teams, making coordination a challenge. The Map Player Count Upgrade offers a solution by enhancing your ability to track teammates and plan strategies more effectively.
What is the Map Player Count Upgrade?
The Map Player Count Upgrade is a purchasable item in R.E.P.O. that adds crucial information to your in-game map. When activated, it displays the number of living players and their locations, giving you a strategic edge in team coordination and survival.
How to Obtain the Map Player Count Upgrade
Step 1: Progress through levels until you reach the Service Station (typically available from level 3 onwards).
Step 2: Look for the Map Player Count Upgrade in the shop inventory. It’s one of the more expensive upgrades, usually priced between $9,000 and $12,000.
Step 3: Purchase the upgrade if you have sufficient funds. Remember, shop inventories are randomized, so the upgrade may not always be available.
Step 4: Once purchased, the upgrade can be used inside the truck as you move to the next level. Activate it by pressing the appropriate key (usually E
on PC).
Benefits of the Map Player Count Upgrade
- Real-time teammate tracking: See the positions of all living teammates on your map.
- Improved coordination: Plan strategies more effectively by knowing everyone’s location.
- Efficient rescues: Quickly locate fallen teammates’ Broken One heads for revival.
- Enhanced situational awareness: Understand your team’s overall status at a glance.
Maximizing the Map Player Count Upgrade
For Team Leaders
If you’re often the last one standing or responsible for team coordination, prioritize this upgrade. It allows you to make informed decisions about when to push forward or retreat to help teammates.
Stacking the Upgrade
Each purchase of the Map Player Count Upgrade reveals one additional teammate on the map. In larger groups, consider having multiple players invest in this upgrade for complete team visibility.
Combining with Other Upgrades
Pair the Map Player Count Upgrade with movement-enhancing upgrades like Sprint Speed or Stamina. This combination allows you to quickly reach teammates in need of assistance.
When to Skip the Map Player Count Upgrade
- Solo play: The upgrade is useless when playing alone. Invest in survival-focused upgrades instead.
- Early game: In the first few levels, prioritize basic upgrades that improve your individual performance.
- Limited funds: If you’re struggling to meet quotas, focus on upgrades that directly increase your looting efficiency.
Alternative Team Coordination Methods
If the Map Player Count Upgrade isn’t available or affordable, consider these alternatives:
- Voice communication: Use clear, concise callouts to share your location and status.
- Ping system: Many co-op games include a way to mark locations for teammates. Check if R.E.P.O. has this feature.
- Buddy system: Always move in pairs to reduce the chances of getting separated.
The Map Player Count Upgrade in R.E.P.O. transforms your map into a powerful team coordination tool. While it comes at a premium price, the strategic advantages it offers can be the difference between a successful extraction and a team wipe in the later, more challenging levels.
