How to Switch Weapons Mid-Hunt in Monster Hunter Wilds
Monster Hunter Wilds introduces an exciting new feature that allows hunters to carry two weapons simultaneously during a hunt. This dual loadout system opens up new strategic possibilities and enhances gameplay flexibility. Let’s explore how to use this new mechanic effectively.
When Does Dual Loadout Become Available?
The ability to carry two weapons is not available from the start of the game. It becomes unlocked during the second main story mission called “Village of Whispering Winds,” which occurs after defeating the Quematrice monster. Upon returning to base camp after this hunt, you’ll receive a Seikret mount equipped with a special saddle designed by Gemma that allows you to carry a secondary weapon.
How to Set Up Your Primary and Secondary Weapons
Before heading out on a hunt, you’ll need to configure your weapon loadout:
Step 1: Visit any camp and enter your tent
Step 2: Select the “Change Equipment” option
Step 3: You’ll see slots for both your primary and secondary weapons
Step 4: Choose your desired weapons from the 14 available weapon types
Your primary weapon will be the one you start with when you begin a hunt, while your secondary weapon will be stored in your Seikret’s saddle. You can set this up at your home base or any pop-up camp you build during a hunt.
How to Switch Weapons During a Hunt
Switching between weapons mid-hunt is straightforward:
  • On consoles: Press the Right D-Pad button
  • On PC: Press the X key
When you trigger the weapon switch, your hunter will automatically mount your Seikret and swap weapons. The current weapon will be stored in the saddle, and you will equip the secondary one instead.
Key points to remember about weapon switching:
  • You can switch weapons while already riding your Seikret
  • Switching weapons makes you vulnerable, so try to distance yourself from monsters before swapping
  • You can switch weapons while moving, making it perfect for tactical repositioning
Best Strategies for Your Dual Loadout
The ability to carry two different weapons opens up more combat possibilities in Monster Hunter Wilds. Different monsters have various elemental and damage-type weaknesses. Having two different weapon types allows you to exploit their weaknesses in a single hunt. Here are two effective strategies to consider:
Melee and Ranged Weapons
Carrying both a melee weapon and a ranged option, like a Bow or Bowgun, gives you great versatility while you hunt monsters. Some monsters in the game can be difficult to hit consistently with melee weapons, making ranged options more usable in those situations.
Speed and Power Balance
Consider combining a slow but powerful weapon like Gunlance with a faster option like Dual Blades or Insect Glaive. This dual loadout will give you the flexibility to deal massive damage when openings appear or switch to quicker attacks against faster monsters like Rey Dau.
Weapon Types and Mechanics
Monster Hunter Wilds features 14 different weapon types, each with unique mechanics and playstyles. Some noteworthy weapons include:
  • Dual Blades: Fast-paced weapons that excel at rapid strikes and mobility. They feature a Demon Mode mechanic that enhances damage and speed at the cost of stamina.
  • Light Bowgun: A versatile ranged weapon that allows for quick movement and the use of various ammunition types.
  • Gunlance: A heavy weapon that combines melee attacks with explosive shells, offering both power and range.
  • Insect Glaive: A unique weapon that allows for aerial combat and comes with an insect companion for additional effects.
Each weapon type has its own set of combos, special moves, and mechanics to master. The dual loadout system allows you to experiment with different weapon combinations and find the perfect setup for your playstyle.
The dual loadout system in Monster Hunter Wilds adds a new layer of strategy to hunts. By carefully selecting complementary weapons and mastering the art of switching mid-combat, hunters can adapt to any situation and take on even the most formidable monsters with increased efficiency. Practice with different weapon combinations to find the perfect loadout for your hunting style.
