Tracking changes in Excel is essential for effective collaboration and auditing. With this feature, you can monitor edits made by multiple users, ensuring data integrity and accountability. It allows you to maintain a detailed history of modifications, making it easier to review, accept, or reject changes.
Things to Remember about Supervising changes in Excel
Before you start tracking changes, keep these points in mind:
Not all Excel edits are tracked. Cell edits are recorded, but formatting changes, formula recalculations, and column/row adjustments aren’t.
You can’t undo changes directly through the change history. You can only manually revert them.
Tracking changes requires a shared workbook, which disables some Excel features like sorting, filtering, and certain formatting options.
By default, the change history is kept for 30 days. You can adjust this retention period.
Workbooks containing tables or XML maps can’t be tracked. Remove these elements before enabling track changes.
How to keep track of changes in Excel
Here’s how to enable and use the track changes feature in Excel.
Method 1: Using a new sheet to track change history in Excel
If you’d prefer to view changes in a separate sheet rather than highlighting them directly in the dataset, Excel offers a feature to generate a new sheet containing a detailed log of all modifications, including timestamps and user names.
Step 1: Go to the Review
tab and click the Track Changes
button in the Changes
group.
Step 2: From the dropdown menu, select Highlight Changes
Step 3: In the Highlight Changes
dialog box, if track changes is already enabled, check only the List changes on a new sheet
option.
Step 4: Click Ok
This action creates a new worksheet named History Sheet
with a comprehensive log of all changes, including when and by whom they were made, and the nature of the data modification.
The generated table includes an Action
column, which indicates whether a change was Won
or Lost
. A Won
status means the change was kept, while a Lost
status indicates the change was overridden by another user.
Ensure your workbook is shared before opening the change history in a new sheet. If not, go to the
Review
tab, select theShare workbook
button from theChanges
section, and select Allow changes by more than one user at the same time option.
Method 2: Enabling the Track Changes Feature
The Track Changes
feature might be hidden in newer Excel versions (Excel 2016, 2019, and Microsoft 365). If the Review
tab only shows the Protect
group with Comment
buttons, follow these steps to enable it:
Step 1: Open your workbook.
Step 2: Go to the File
menu and select Options
at the bottom left.
Step 3: In the Excel Options
dialog box, select Customize Ribbon
Step 4: Under Choose commands from
, select All Commands
Step 5: Under the Main Tab
list, find and select Review Tab
Step 6: Select New Group
at the bottom.
Step 7: A new group will appear under the Review
tab; right-click it to rename it.
Step 8: In the Rename
dialog box, enter the name Track Changes
and click Ok
Step 9: From the Commands
list, select the following four commands and drag them into the Track Changes
group:
Track Changes (Legacy)
Compare and Merge Workbooks (Legacy)
Share Workbook (Legacy)
Protect Sharing (Legacy)
Step 10: Click Ok
to close the Excel options
window.
Now, a new group with these four buttons will be visible in the Excel Review
tab.
Step 11: Click on Share Workbook
to enable the Accept/Reject Changes
options.
Step 12: Select the Use the old shared workbooks feature instead of the new co-authoring experience
option.
Step 13: Check who has access to the workbook now and add or remove a user.
Step 14: Press Ok
Method 3: Turning On Track Changes
By default, the tracking changes feature is off. To activate it:
button from the Changes
group.
Step 3: The Highlight Changes
dialogue box will appear.
Step 4: Check the Track changes while editing. This also shares your workbook. option.
Step 5: Under the Highlight which changes
box, select the time and people whose changes you want to see in the Excel sheet. Choose all times and everyone, if required.
Step 6: Check the Highlight changes on the screen
option.
Step 7: Click Ok
Excel will now highlight any changes made to the workbook from this point forward.
If your file isn’t already saved, Excel will prompt you to save it before enabling track changes.
Method 4: Accepting or Rejecting Changes
As the workbook owner, you can accept or reject changes made by others.
tab and select the Track Changes
group.
Step 2: From the drop-down menu, select Accept/Reject Changes
Step 3: The Select Changes to Accept or Reject
dialog box will appear.
Step 4: Under Which changes
, select the criteria for accepting or rejecting changes (e.g., Not yet reviewed
Step 5: In the Who
box, select the users whose changes you want to review (e.g., Everyone
Step 6: Leave the Where
box empty to review changes across the entire workbook.
Step 7: Click Ok
Excel will then present each change one by one, allowing you to accept or reject each individually, or all at once.
Whether you accept or reject a change, the highlighting will remain until you disable the track changes feature entirely.
Method 5: Highlighting Changes on Screen
When track changes is enabled, Excel highlights changed cells directly in the worksheet.
Excel highlights the row numbers and column letters in a maroon color. The cells are highlighted in different colors depending on who edited them.
Cell borders are colored, and a triangle appears in the top-left corner of changed cells. Hovering over this triangle reveals information about the user and the time of the change.
Method 6: Setting the Duration for Keeping Change History
The default setting is to keep the change history for 30 days. To modify this:
tab and select the Share Workbook
section.
Step 2: The Share Workbook
Step 3: Select the Advanced
tab.
Step 4: Under Track Changes
, specify the number of days you want to retain the change history.
Step 5: Click Ok
Method 7: Turning Off Track Changes
To disable the track changes feature:
group.
dialog box, uncheck the Track changes while editing. This also shares your workbook. option.
This guide covered how to track changes in Excel, including enabling and disabling the feature, highlighting changes, setting history duration, and accepting/rejecting modifications. You can choose to view changes directly or in a separate sheet.
