In this guide, we’ll walk through setting up an agent node in Jenkins. Adding a Linux-based agent node to your Jenkins master server allows you to distribute the pipeline workload and execute jobs across diverse environments.
Prerequisites
Before proceeding, ensure the following requirements are met:
A running Jenkins master server.
A Linux machine to serve as the agent.
SSH access to the agent machine.
sudo
privileges on the agent machine.
Note: This guide uses Rocky Linux 9 for the agent machine.
Setup Agent Node in Jenkins
Let’s begin setting up the agent node.
Establishing Agent Connection via JNLP (Jenkins Node Protocol)
The most effective approach for connecting Jenkins agents involves utilizing the JNLP protocol. This method offers enhanced security and simplified configuration compared to SSH. Here’s how to set it up:
Step 1: Navigate to the Jenkins dashboard and click on Manage Jenkins
Step 2: Click on Nodes
then New Node
Step 3: Enter a name for the node (e.g., jnlp-agent
). Select Permanent Agent
and click OK
Step 4: Configure the node settings:
Description: Enter a description for the agent (e.g., “JNLP Agent”).
# of executors: Set the number of concurrent jobs this agent can run.
Remote root directory: Specify the directory on the agent where Jenkins will store temporary files (e.g.,
/home/jenkins/agent
Labels: Add labels to categorize the agent (e.g.,
jnlp
Usage: Choose
Use this node as much as possible
Launch method: Select
Launch agent by connecting it to the controller
Availability: Choose when the agent should be online.
Step 5: Save the node configuration. Jenkins will provide a JNLP agent secret and instructions for connecting the agent.
Step 6: On the agent machine, download the agent.jar
file from the Jenkins master (URL provided on the agent’s page).
Step 7: Run the following command on the agent machine, replacing the <jenkins_url>
, <agent_name>
, and <agent_secret>
with the appropriate values:
java -jar agent.jar -jnlpUrl <jenkins_url>/computer/<agent_name>/jenkins-agent.jnlp -secret <agent_secret>
Step 8: Verify that the agent node is connected and online in the Jenkins dashboard.
Alternative Method: Setting up Agent Node via SSH
1) Prepare the Agent Machine
Let’s prepare the agent machine. SSH into the agent node and install Java using the following command:
$ sudo dnf install java-21-openjdk -y
After installation, verify the Java version:
$ java --version
Next, create a Jenkins user, add it to the wheel
group, and generate SSH keys for the Jenkins user.
Run the following commands:
$ sudo useradd -G wheel jenkins
$ sudo passwd jenkins
$ su - jenkins
$ ssh-keygen -t rsa
$ cd .ssh/
$ touch authorized_keys
$ cat id_rsa.pub > authorized_keys
View the content of Jenkins user’s private key using:
$ cat id_rsa
You’ll need this private key when creating credentials in the Jenkins UI.
2) Create Credentials for Agent Node
Navigate to Manage Jenkins
→ Under Security
→ Click on Credentials
Follow these steps:
Step 1: Click Add Credentials
Step 2: Select SSH Username with private key
Step 3: Set scope
to Global
Step 4: Enter ID
: jenkins-agent-ssh
Step 5: Description
: SSH key for Linux agent
Step 6: Username
: jenkins
Step 7: Private Key
: Select Enter directly
Step 8: Paste the private key from the agent machine.
Step 9: Click Add
3) Add the Agent Node
With the prerequisites completed, proceed to add the agent node.
→ Under System Configuration
→ Click on Nodes
→ Choose New Node
Configure these settings:
Step 1: Name
: linux-agent
Step 2: Description
: Linux agent
Step 3: Number of executors
: 2
Step 4: Remote root directory
: /home/jenkins/
Step 5: Labels
: linux
Step 6: Usage
: Use this node as much as possible
Step 7: Launch method
: Launch agents via SSH
Step 8: Host
: [Your Agent IP]
Step 9: Credentials
: Choose jenkins
Step 10: Host Key Verification Strategy
: Non verifying
This confirms that a Linux-based agent node has been added to your Jenkins master server.
To test the functionality of the newly added agent, let’s run a sample job on it.
4) Create & Run Job on New Agent node
From the Jenkins GUI, create a freestyle project job and force the job to run on the newly added Linux-based agent node.
Console logs of the job will confirm that it has been executed on the new Linux-based agent node.
Following these steps, you can successfully set up an agent node in Jenkins, enabling distributed builds and tests across your infrastructure.
