How to Set Up Fubo TV on Your Samsung Smart TV
Fubo TV offers a compelling streaming experience with over 200 live channels spanning sports, news, and entertainment. For Samsung Smart TV owners looking to access Fubo’s content library on the big screen, the setup process is straightforward but requires a few key steps. This guide will walk you through installing the Fubo TV app and getting it up and running on your Samsung Smart TV.
Download and Install the Fubo TV App
Step 1: Press the Home button on your Samsung TV remote to access the main menu.
Step 2: Navigate to and select the “Apps” icon to open the Samsung app store.
Step 3: Use the search function (magnifying glass icon) in the top-right corner of the Apps screen.
Step 4: Type “Fubo TV” using the on-screen keyboard and select the app from the search results.
Step 5: Click the “Install” button to download and install the Fubo TV app on your Samsung Smart TV.
Once installed, the Fubo TV app will appear on your TV’s home screen or in the Apps section.
Activate Your Fubo TV Account
Step 1: Open the newly installed Fubo TV app on your Samsung Smart TV.
Step 2: You’ll see two options: “Sign Up” or “Sign In”. If you already have a Fubo TV account, select “Sign In”.
Step 3: The app will display an activation code on your TV screen. Make note of this code as you’ll need it for the next step.
Step 4: Using a web browser on your computer or mobile device, visit fubo.tv/connect.
Step 5: Enter the activation code displayed on your TV into the provided field on the website.
Step 6: Click “Submit” or “Activate” to link your Fubo TV account to your Samsung Smart TV.
After successful activation, your Samsung Smart TV will be connected to your Fubo TV account, and you can start streaming content immediately.
Troubleshooting Tips
If you encounter any issues during the setup process:
  • Ensure your Samsung Smart TV is connected to the internet and that the connection is stable.
  • Verify that your Fubo TV subscription is active and in good standing.
  • If the activation code doesn’t work, try generating a new one by restarting the Fubo TV app on your TV.
  • Check that your Samsung TV’s software is up to date, as outdated firmware can cause compatibility issues.
Alternative: Casting from Mobile Devices
For users who prefer to control Fubo TV from their smartphones, both Android and iOS devices offer casting options:
Android Users
Step 1: Ensure your Samsung TV and Android phone are on the same Wi-Fi network.
Step 2: Install the Fubo TV app from the Google Play Store and sign in to your account.
Step 3: Start playing content in the Fubo TV app, then tap the Cast icon (usually looks like a TV with a Wi-Fi symbol).
Step 4: Select your Samsung TV from the list of available devices to begin casting.
iOS Users
Step 1: Make sure AirPlay is enabled on your Samsung TV (found in the TV’s settings under “General” or “Apple AirPlay Settings”).
Step 2: Download the Fubo TV app from the App Store and log in.
Step 3: Play content in the Fubo TV app, then tap the AirPlay icon (a rectangle with a triangle at the bottom).
Step 4: Choose your Samsung TV from the list of AirPlay devices to start streaming.
Setting up Fubo TV on your Samsung Smart TV opens up a world of live and on-demand content. Whether you choose to use the native app or cast from your mobile device, you’ll be enjoying Fubo’s extensive channel lineup on your big screen in no time. Remember to keep both your TV’s software and the Fubo TV app updated for the best streaming experience.
