How to Save Your Progress in Schedule 1
Schedule 1 is an immersive drug empire simulation game that requires careful planning and strategy. As you build your criminal enterprise, it’s crucial to save your progress regularly. This article explores the various methods to save your game in Schedule 1, ensuring you don’t lose hours of hard work.
Using the Wall-Mounted Save Button
The most straightforward way to save your game in Schedule 1 is by using the wall-mounted save button found in properties you own.
Step 1: Locate the save button near the front door of your property, usually next to the light switch.
Step 2: Approach the button and press E to interact with it.
Step 3: Your game will be saved instantly, preserving all your current progress.
This method allows you to save at any time during the day, giving you peace of mind before undertaking risky operations or logging off for the night.
Automatic Saving Through Sleep
Schedule 1 also features an auto-save function tied to your character’s sleep cycle.
Step 1: Find a bed in a property you own.
Step 2: Interact with the bed to make your character sleep.
Step 3: The game will automatically save as you transition to the next in-game day.
While convenient, this method limits your ability to save mid-day. It’s best used in conjunction with manual saves for maximum security.
Using Console Commands to Force a Save
For players who want more control over their saves, Schedule 1 offers a console command option. However, use this method cautiously as it’s not the developer-intended way to save.
Step 1: Enable the console in the game settings menu.
Step 2: Press the ~ (tilde) key to open the console window.
Step 3: Type save and press Enter to force a game save.
This method allows you to save anywhere, anytime, but should be used sparingly to maintain the intended gameplay experience.
Locating Your Save Files
Understanding where Schedule 1 stores your save files can be helpful for backup purposes or troubleshooting.
Step 1: Open File Explorer on your computer.
Step 2: Navigate to the following directory:
C:\Users\<Your Username>\AppData\LocalLow\TVGS\Schedule I\Saves
Step 3: Here you’ll find your save game files, which you can back up or transfer to another device if needed.
Best Practices for Saving in Schedule 1
To ensure you never lose significant progress:
  • Save manually before and after major operations or transactions.
  • Utilize the auto-save function by sleeping regularly, but don’t rely on it exclusively.
  • Create multiple save files at different points in your playthrough.
  • Periodically back up your save files to an external storage device.
Mastering the art of saving in Schedule 1 is as crucial as building your drug empire. By utilizing these various save methods and following best practices, you’ll safeguard your progress and be ready for whatever challenges the game throws your way.
