Network connectivity issues can be frustrating on Android devices. Resetting network settings is often an effective troubleshooting step to resolve problems with Wi-Fi, mobile data, or Bluetooth connections. This process restores all network-related settings to their default state without affecting your personal data.
What Happens When You Reset Network Settings
Before proceeding, it’s important to understand what resetting network settings will do:
- Deletes all saved Wi-Fi networks and passwords
- Clears paired Bluetooth devices
- Resets mobile data and APN settings to default
- Removes any configured VPN settings
- Turns off airplane mode if enabled
- Resets network selection mode to automatic
Make sure to back up any important Wi-Fi passwords or Bluetooth pairings before resetting.
How to Reset Network Settings on Stock Android
For devices running stock or near-stock Android:
Step 1: Open the Settings app on your Android device.
Step 2: Scroll down and tap on “System”.
Step 3: Tap on “Advanced” to reveal additional options.
Step 4: Select “Reset options”.
Step 5: Tap on “Reset Wi-Fi, mobile & Bluetooth”.
Step 6: Review the information about what will be reset, then tap “Reset settings”.
Step 7: Enter your device PIN or password if prompted.
Step 8: Tap “Reset settings” again to confirm.
Your device will restart and network settings will be restored to default.
How to Reset Network Settings on Samsung Devices
Samsung devices have a slightly different process:
Step 1: Open the Settings app.
Step 2: Scroll down and tap on “General management”.
Step 3: Tap on “Reset”.
Step 4: Select “Reset network settings”.
Step 5: Tap “Reset settings” at the bottom of the screen.
Step 6: Enter your PIN or password if prompted.
Step 7: Tap “Reset” to confirm.
Resetting Network Settings on Other Android Devices
While the exact steps may vary slightly on devices from other manufacturers like LG, Motorola, or Huawei, the general process is similar:
- Open Settings
- Look for a section called “System”, “General Management”, or something similar
- Find “Reset” or “Reset options”
- Select the option to reset network settings
- Confirm the action
If you can’t find the option, try searching for “reset” in the Settings search bar.
After Resetting Network Settings
Once the reset is complete:
- Reconnect to your Wi-Fi networks
- Re-pair Bluetooth devices
- Reconfigure any VPN settings
- Check your mobile data settings
If network issues persist after resetting, contact your device manufacturer or mobile carrier for further assistance.
Resetting network settings can often resolve connectivity problems without the need for more drastic measures like a factory reset. If you continue to experience issues, consider updating your device’s software or consulting with a professional technician.
