How to Replace Your AirTag Battery in 2025: A Simple Guide
Apple’s AirTag is a reliable tracking device that helps you keep tabs on your belongings, but its battery isn’t rechargeable. When the battery runs low, you’ll need to replace it to keep your AirTag functional. Here’s everything you need to know about replacing the battery in your AirTag, including the type of battery it uses, how to check its status, and step-by-step instructions for a smooth replacement process.
What Type of Battery Does an AirTag Use?
The AirTag uses a CR2032 lithium coin cell battery, a common type found in watches, calculators, and other small electronics. These batteries are widely available at electronics stores, supermarkets, and online retailers. Apple recommends using a bitterant-coated CR2032 battery, which discourages accidental ingestion by children. Brands like Energizer and Panasonic offer CR2032 batteries specifically labeled as compatible with AirTags.
When purchasing a replacement battery, ensure it’s a CR2032 model and check the packaging for compatibility with Apple AirTags. Avoid batteries with coatings that might interfere with the AirTag’s functionality.
How to Check Your AirTag’s Battery Status
Before replacing the battery, it’s important to confirm whether your AirTag’s battery is low. Apple makes this easy with built-in notifications and the Find My app. Here’s how to check:
  1. Low Battery Notification: Your iPhone will alert you when the AirTag’s battery is running low. This notification gives you ample time to replace the battery before it dies.
  2. Find My App: Open the Find My app, tap the Items tab, and select your AirTag. If the battery is low, you’ll see a Low Battery indicator below the AirTag’s name.
Step-by-Step Guide to Replacing the AirTag Battery
Replacing the AirTag battery is a straightforward process that requires no special tools. Follow these steps:
Step 1: Locate the stainless steel battery cover on the back of your AirTag. Press down firmly and rotate the cover counterclockwise until it stops.
Step 2: Lift the cover to reveal the old battery. Carefully remove it from the compartment.
Step 3: Insert the new CR2032 battery, ensuring the positive side (marked with a “+” sign) faces up. You’ll hear a chime indicating the battery is properly connected.
Step 4: Align the three tabs on the cover with the slots on the AirTag. Press down and rotate the cover clockwise until it locks into place.
Tips for Extending AirTag Battery Life
To maximize the lifespan of your AirTag’s battery, consider these tips:
  • Limit Precision Finding: Frequent use of Precision Finding can drain the battery faster. Use this feature only when necessary.
  • Store in Moderate Temperatures: Extreme heat or cold can reduce battery efficiency. Keep your AirTag in a temperate environment.
  • Use High-Quality Batteries: Opt for reputable brands like Energizer or Panasonic to ensure longer battery life.
Replacing your AirTag’s battery is a quick and easy task that ensures your tracker remains functional for another year. By following these steps and tips, you can keep your AirTag ready to locate your valuables whenever you need it.
