Roblox Evade is an exciting survival game where players must outrun and outsmart dangerous NextBots. To give yourself an edge, you can use special codes to unlock free rewards like tokens, cosmetic items, and more. Let’s dive into the latest working codes for March 2025 and how to redeem them.
Current Active Codes for Roblox Evade (March 2025)
Here are the most recent codes you can use to claim rewards in Evade:
theaftermath
- Rewards unknown (NEW)apology
- 1000 Tokensthebig5
- 555 Tokens444
- 444 Tokens222
- 222 Tokenstherealdeal
- Bird Badge cosmetic item
Be sure to redeem these codes quickly, as they may expire without notice.
How to Redeem Codes in Evade
Redeeming codes in Evade is a straightforward process. Follow these steps to claim your rewards:
Step 1: Launch Roblox and open the Evade game.
Step 2: Look for the Twitter bird icon in the bottom right corner of the screen.
Step 3: Click on the Twitter icon to open the code redemption window.
Step 4: Enter an active code exactly as shown above, including any capital letters or numbers.
Step 5: Press Enter or click the Submit button to redeem your code.
Step 6: If successful, you’ll receive a confirmation message and your rewards will be added to your account.
If a code doesn’t work, double-check that you’ve entered it correctly. Codes are case-sensitive, so make sure to use the exact capitalization shown.
Tips for Using Evade Codes
- Codes typically provide Tokens, which can be used to purchase cosmetic items and other upgrades in the game.
- Some codes offer unique badges or cosmetic items that can’t be obtained through regular gameplay.
- New codes are often released during game updates or special events, so check back regularly.
- Codes have a limited lifespan, so redeem them as soon as possible after they’re released.
Staying Updated on New Evade Codes
To ensure you never miss out on new codes, try these methods:
- Follow the official Evade Twitter account @HexagonDCRoblox for announcements.
- Join the Evade Discord server to get code notifications and interact with other players.
- Bookmark and regularly check reputable Roblox code websites that update their lists frequently.
Making the Most of Your Rewards
Once you’ve redeemed codes and received Tokens or items, here’s how to use them effectively:
- Spend Tokens wisely on cosmetic items that fit your playstyle or help you blend in with the environment.
- Experiment with different character customizations to find the perfect look for evading NextBots.
- Share your favorite cosmetic combinations with friends or in the Evade community.
Gameplay Tips for Evade
While codes can give you a boost, mastering the game itself is key to survival. Here are some quick tips:
- Learn the map layouts to find the best hiding spots and escape routes.
- Use the shift key to sprint, but be mindful of your stamina bar.
- Work together with other players to distract NextBots and revive fallen teammates.
- Listen for audio cues that signal when a NextBot is nearby.
Roblox Evade offers an intense, adrenaline-pumping experience as you dodge relentless NextBots. By using these codes and honing your skills, you’ll be well-equipped to survive longer and climb the leaderboards. Keep an eye out for new codes, and most importantly, have fun evading those NextBots!
