How to Reconnect with Someone After Using Facebook's Take a Break Feature
Facebook’s “Take a Break” feature allows users to temporarily limit interactions with specific friends without unfriending them. But what happens when you’re ready to reconnect? This guide explains how to reverse the Take a Break settings and restore normal Facebook interactions.
What is Facebook’s Take a Break Feature?
Facebook’s Take a Break option lets users reduce their exposure to a specific friend’s content without severing the connection completely. When enabled, it:
  • Limits the visibility of your posts to that person
  • Reduces how often you see their posts in your News Feed
  • Allows you to edit privacy settings on past posts you’re tagged in together
This feature can be helpful during temporary life changes or periods of distance from someone. However, circumstances change, and you may want to restore full interactions.
How to Reverse Take a Break Settings
Undoing Take a Break is a straightforward process that can be done through the Facebook mobile app:
Step 1: Open the Facebook app and tap the search icon at the top of the screen.
Step 2: Type in the name of the person you previously set to Take a Break and tap on their profile.
Step 3: Tap the “Friends” button below their profile picture.
Step 4: Select “Take a Break” from the menu options.
Step 5: Review each Take a Break setting you previously enabled and tap to disable them:
  • “See less of [Name]”
  • “Limit what [Name] will see”
  • “Edit who can see past posts”
Step 6: Tap “Save” after adjusting each setting to apply the changes.
After completing these steps, your Facebook interactions with this person should return to normal. You’ll start seeing their posts in your News Feed again, and they’ll have standard visibility of your content (based on your general privacy settings).
Additional Considerations
  • Gradual Reintegration: If you’re hesitant about fully reversing all settings at once, consider adjusting them incrementally over time.
  • Communication: Depending on the situation, you might want to have a conversation with the person to explain the changes in your online interaction.
  • Privacy Check: After reversing Take a Break, review your general privacy settings to ensure they align with your current preferences.
  • News Feed Preferences: If you want more control over whose content you see, explore Facebook’s News Feed Preferences for additional customization options.
Reconnecting on social media can be a positive step in rebuilding or strengthening relationships. Facebook’s flexible features allow you to manage these digital interactions at your own pace.
