How to Play Four in a Row on iMessage
Ever wanted to play a quick game of connect four with your buddies directly through iMessage? You can do just that by using the GamePigeon app. This lets you play a digital version of “Four in a Row”, perfect for a bit of strategic fun during downtime. While “Four in a Row” isn’t a standalone app on the iMessage store, it comes as part of the GamePigeon app, which contains tons of other games too.
The goal in ‘Four in a Row’ is simple: be the first to connect four of your colored pieces in a row, whether vertically, horizontally, or diagonally, while also trying to stop your opponent from doing the same. Players alternate turns, dropping pieces into the grid, so planning your moves is crucial to outsmarting your opponent.
Downloading the GamePigeon app from iMessage App Store
To get started, you need to download the GamePigeon app, which includes “Four in a Row” along with many other games.
  1. Launch the Messages app on your iPhone, either from your home screen or the app library.
  2. Choose an existing chat or start a new one by hitting the compose icon.
  3. Tap the gray App Store icon, which is located in the app bar above your keyboard. This opens the iMessage App Store.
  4. In the App Store overlay, find the search icon in the top-right corner and tap it.
  5. Type GamePigeon into the search field and then tap Search on the keyboard.
  6. Find the GamePigeon app in the search results and tap Get to download it. You may need to confirm the download with your Apple ID.
    Note: If you already downloaded GamePigeon, you might see a cloud icon instead of Get.
Starting a game of four in a row
After you and your friend both have GamePigeon, you can start playing “Four in a Row” together.
  1. Launch the Messages app and select the conversation with the person you want to play with.
  2. In the app bar above the keyboard, scroll until you find the GamePigeon icon and tap it to see the available games.
  3. Choose the “Four in a Row” game from the list.
  4. Add an optional message, then hit the Send button to invite them to play.
Once your contact accepts the invite, they can tap on the game to take their turn. Players take turns placing their colored pieces, trying to get four in a row and also blocking their opponent.
  1. When it’s your turn, tap on the column to drop your piece. You can also press and hold to drag the piece across the grid. Once you’ve chosen your position, tap Send.
    Your goal is to be the first to align four pieces of the same color while strategically blocking your opponent.
Adjusting sound and music settings
If you prefer not to have music or sounds while playing, you can easily change these options in the game’s settings.
  1. During your turn in “Four in a Row”, tap the gear icon in the bottom right corner.
  2. Tap the Music button to toggle the music on or off and use the Sound button to do the same for sound effects.
You can also customize your avatar’s look using various options for hair, facial expressions, glasses, hats, clothing, and more from the customization menu above the sound settings.
Playing “Four in a Row” on iMessage via the GamePigeon app provides an easy way to enjoy a classic game and test your skills against friends.
