Metro Life City RP offers an exciting challenge for Roblox players participating in The Hunt: Mega Edition event. This roleplaying game tasks players with completing a series of quests to obtain the coveted Mega Token. Let’s explore how to navigate this urban adventure and claim your prize.
Starting Your Quest
To begin your journey, head to the Metro Hall in the game. Use the Map option in your Mobile panel to teleport there quickly. Once inside, locate the Mayor’s office on the right side of the building. Look for a purple Mayor doll sitting on a desk - this is your first point of contact.
Interact with the Mayor doll to receive your initial instructions. You’ll be tasked with collecting three pieces of a map by completing various quests around the city. Each quest will test different skills and take you to unique locations within Metro Life.
Completing the Map Piece Quests
Quest 1: Tree Trimming at the Fire Department
Step 1: Teleport to the Fire Department using your Map function.
Step 2: Head to the back of the building to find an NPC who will explain that a nearby tree needs trimming.
Step 3: Locate the tree adjacent to the Fire Department building.
Step 4: Use the Chainsaw
from your inventory to cut down the marked branches.
Step 5: Spawn a Ladder
from your inventory to reach the upper parts of the tree if needed.
Step 6: Return to the NPC to report your completed task and receive the first map piece.
Quest 2: Cleaning the Library
Step 1: Use your Map function to teleport to Ascend High School.
Step 2: Enter the main building and take the first left near the Reception desk to reach the Library.
Step 3: Speak with the librarian NPC who will explain that vandals have spray-painted the glass panels.
Step 4: Use a cleaning tool from your inventory to remove the graffiti from all marked areas.
Step 5: Return to the librarian to confirm completion and receive the second map piece.
Quest 3: Rescuing a Lost Kitten
Step 1: Teleport to Paradise Hotel using your Map function.
Step 2: Take the elevator to the second floor and locate an NPC near room 205.
Step 3: The NPC will inform you about her missing kitten. Accept the quest to find it.
Step 4: Search the terrace area until you spot a small black kitten on the south edge.
Step 5: Carefully approach and pick up the kitten.
Step 6: Return the kitten to the NPC on the second floor to receive the final map piece.
Assembling the Map and Locating the Vault
With all three map pieces in hand, return to the Mayor at Metro Hall. He will assemble the complete map for you. Examine it closely to identify four colored dots (red, yellow, green, and blue) connected by lines forming an X.
Step 1: Locate the center of the X on your map.
Step 2: Travel to this location in the game world.
Step 3: Use a Shovel
from your inventory to dig in the area.
Step 4: After some digging, you’ll unearth a metallic vault with four colored locks.
Finding the Vault Codes
To open the vault, you’ll need to collect four color-coded numbers from around the city:
Red Code
- Travel to the red dot on your map.
- Look for an open garage-like area.
- Search the walls carefully to find a number written on one of them.
Yellow Code
- Head to the yellow marker on your map.
- You’ll find a construction site with a prominent crane.
- Use your
Ladder
to climb the crane. - Locate the number on the crane’s platform.
Green Code
- Go to the green marker near a FuelPlus gas station.
- Look for a small pond with two or three trees nearby.
- Check the branch of the central green tree for a number.
Blue Code
- At the blue marker, find a building with large glass panels.
- Go to the south side of this building.
- Look for a number written on one of the pillars.
Opening the Vault and Claiming Your Prize
Step 1: Return to the unearthed vault location.
Step 2: Enter each colored code into its corresponding lock on the vault.
Step 3: When all four codes are correctly entered, the vault will unlock.
Step 4: Open the vault to find a Time Capsule inside.
Step 5: Interact with the Time Capsule to obtain your Mega Token for Metro Life City RP.
Congratulations on completing this challenging quest! You’ve explored the city, solved puzzles, and claimed your reward. Don’t forget that The Hunt: Mega Edition event ends on March 24, 2025, so make sure to collect tokens from other participating games before time runs out.
