How to Fix iMessage Not Showing as Delivered on iPhone
iMessage is a popular messaging service for Apple users, but it can sometimes encounter issues. One common problem is when messages don’t show as “Delivered” even after being sent. This article will explore various solutions to resolve this issue and get your iMessages working correctly again.
Check Your Internet Connection
The most common reason for iMessage delivery problems is a poor internet connection. iMessage requires a stable internet connection to function properly.
Step 1: Open Control Center by swiping down from the top-right corner of your iPhone screen.
Step 2: Check if Wi-Fi or Cellular Data is enabled. If not, tap the respective icon to turn it on.
Step 3: If you’re using Wi-Fi, try switching to cellular data or vice versa to see if the issue persists.
Step 4: If you’re still having problems, try resetting your network settings:
  1. Go to Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings.
  2. Enter your passcode when prompted.
  3. Confirm by tapping “Reset Network Settings” again.
Verify iMessage is Enabled
Sometimes, iMessage can be accidentally disabled, causing delivery issues.
Step 1: Go to Settings > Messages.
Step 2: Ensure the iMessage toggle is switched on (it should be green).
Step 3: If it’s already on, try turning it off and on again:
  1. Toggle iMessage off.
  2. Wait for about 30 seconds.
  3. Toggle iMessage back on.
Check Apple’s System Status
Apple’s servers might be experiencing issues, which can affect iMessage delivery.
Step 1: Visit Apple’s System Status page (Apple - Support - System Status).
Step 2: Look for “iMessage” in the list of services.
Step 3: If there’s a yellow or red dot next to iMessage, it indicates a known issue. In this case, you’ll need to wait for Apple to resolve the problem.
Update iOS
Outdated iOS versions can sometimes cause iMessage problems. Keeping your iPhone up-to-date can resolve many issues.
Step 1: Go to Settings > General > Software Update.
Step 2: If an update is available, tap “Download and Install”.
Step 3: Follow the on-screen instructions to complete the update process.
Force Restart Your iPhone
A force restart can often resolve temporary glitches affecting iMessage.
For iPhone 8 or later:
Step 1: Quickly press and release the Volume Up button.
Step 2: Quickly press and release the Volume Down button.
Step 3: Press and hold the Side button until you see the Apple logo.
For iPhone 7 or 7 Plus:
Step 1: Press and hold both the Volume Down button and the Sleep/Wake button.
Step 2: Keep holding until you see the Apple logo.
For iPhone 6s or earlier:
Step 1: Press and hold both the Home button and the Sleep/Wake button.
Sign Out and Back Into Your Apple ID
Signing out of your Apple ID and then signing back in can sometimes resolve iMessage issues.
Step 1: Go to Settings > Messages > Send & Receive.
Step 2: Tap your Apple ID at the top of the screen.
Step 3: Select “Sign Out”.
Step 4: Wait for a few minutes, then sign back in with your Apple ID.
Reset All Settings
If none of the above methods work, you can try resetting all settings on your iPhone. This won’t delete your data, but it will reset all your preferences to default.
Step 1: Go to Settings > General > Transfer or Reset iPhone > Reset.
Step 2: Tap “Reset All Settings”.
Step 3: Enter your passcode if prompted.
Step 4: Confirm by tapping “Reset All Settings” again.
After trying these methods, your iMessage should start showing as “Delivered” once again. If you’re still experiencing issues, it might be worth contacting Apple Support for further assistance. They can provide more specialized help based on your specific situation and device.
Remember, patience is key when troubleshooting tech issues. Sometimes, simply waiting a bit longer can resolve the problem, as network congestion or temporary server issues can cause delayed message delivery.
