The DirectX Runtime error in Hogwarts Legacy can prevent the game from launching properly on Windows PCs. This frustrating issue typically displays the message “The following component(s) are required to run this program: DirectX Runtime.” Fortunately, there are several troubleshooting steps you can take to resolve this error and get back to exploring the magical world of Hogwarts.
Update Your Graphics Drivers
Outdated graphics drivers are a common cause of DirectX-related errors. Updating to the latest drivers often resolves compatibility issues with newer games like Hogwarts Legacy.
Step 1: Press Windows Key + X
and select “Device Manager” from the menu.
Step 2: Expand the “Display adapters” section and right-click on your graphics card.
Step 3: Choose “Update driver” and select “Search automatically for drivers”.
Step 4: If Windows finds a newer driver version, follow the prompts to install it.
Step 5: Restart your computer after the driver update completes.
For the best results, you can also download the latest drivers directly from your graphics card manufacturer’s website (NVIDIA, AMD, or Intel).
Reinstall DirectX
Sometimes the DirectX files on your system may become corrupted or outdated. Reinstalling DirectX can often resolve runtime errors.
Step 1: Open the Hogwarts Legacy installation folder in Steam. The default path is:
C:\Program Files (x86)\Steam\steamapps\common\Hogwarts Legacy
Step 2: Navigate to the _CommonRedist\DirectX
folder.
Step 3: Run the DXSETUP.exe
file and follow the installation prompts.
Step 4: Restart your computer after the installation completes.
If you can’t find the DirectX installer in the game folder, you can download the latest version from the official Microsoft website.
Verify Game File Integrity
Corrupted game files can cause various errors, including DirectX issues. Verifying the integrity of game files through Steam can help identify and fix these problems.
Step 1: Open Steam and go to your Library.
Step 2: Right-click on Hogwarts Legacy and select “Properties”.
Step 3: Go to the “Local Files” tab and click “Verify integrity of game files”.
Step 4: Wait for the process to complete, which may take several minutes.
Step 5: If any files are found to be corrupted or missing, Steam will automatically download and replace them.
Run the DirectX Diagnostic Tool
The DirectX Diagnostic Tool (DxDiag) can help identify issues with your DirectX installation and provide valuable information for troubleshooting.
Step 1: Press Windows Key + R
to open the Run dialog.
Step 2: Type dxdiag
and press Enter.
Step 3: In the DirectX Diagnostic Tool, check the “System” tab for your current DirectX version.
Step 4: Review the “Display” tab for any reported problems with DirectX features.
Step 5: If you notice any issues or outdated components, consider updating Windows or reinstalling DirectX.
Update Windows
Ensuring your Windows operating system is up to date can resolve many compatibility issues and provide the latest DirectX updates.
Step 1: Press Windows Key + I
to open Settings.
Step 2: Go to “Windows Update” and click “Check for updates”.
Step 3: If updates are available, click “Download and install”.
Step 4: Restart your computer after the updates are installed.
Run Hogwarts Legacy as Administrator
Sometimes, running the game with elevated permissions can bypass DirectX-related errors.
Step 1: Locate the Hogwarts Legacy executable file (usually HogwartsLegacy.exe
) in your Steam games folder.
Step 2: Right-click on the file and select “Properties”.
Step 3: Go to the “Compatibility” tab.
Step 4: Check the box next to “Run this program as an administrator”.
Step 5: Click “Apply” and then “OK”.
Step 6: Launch the game through Steam to see if the error is resolved.
By following these troubleshooting steps, you should be able to resolve the DirectX Runtime error in Hogwarts Legacy and start your magical adventure at Hogwarts. If you continue to experience issues, consider reaching out to the game’s support team or consulting community forums for additional assistance.
Remember to keep your system updated and regularly check for game patches, as developers often release fixes for common issues in subsequent updates.
