How to Fix 404 Not Found Errors: A Complete Troubleshooting Guide
The dreaded 404 Not Found error can frustrate both website visitors and administrators alike. This HTTP status code indicates that a server couldn’t locate the requested webpage. Whether you’re encountering this error as a user or managing a website, understanding its causes and solutions is crucial for a smooth online experience.
Common Causes of 404 Errors
404 errors typically occur due to several reasons:
  • Mistyped URLs
  • Deleted or moved pages without proper redirects
  • Broken internal or external links
  • Server configuration issues
  • DNS problems
Fixing 404 Errors as a Website Visitor
If you encounter a 404 error while browsing, try these troubleshooting steps:
Refresh the Page
Sometimes, a simple refresh can resolve temporary glitches.
Step 1: Press F5 or click the refresh button in your browser.
Step 2: Wait for the page to reload and check if the error persists.
Double-Check the URL
Typos in web addresses are a common cause of 404 errors.
Step 1: Carefully review the URL in the address bar for any spelling mistakes.
Step 2: Pay attention to common errors like missing slashes or incorrect file extensions (e.g., .html vs .htm).
Step 3: If you find any mistakes, correct them and press Enter to reload the page.
Clear Browser Cache and Cookies
Outdated cached data can sometimes lead to 404 errors.
Step 1: Open your browser settings.
Step 2: Navigate to the privacy or history section.
Step 3: Select the option to clear browsing data.
Step 4: Ensure both “Cached images and files” and “Cookies” are checked.
Step 5: Click “Clear data” and try accessing the page again.
Try a Different Browser or Device
If the error persists, test the URL on another browser or device to determine if it’s a local issue.
Step 1: Open a different web browser (e.g., Chrome, Firefox, Safari) on your device.
Step 2: Enter the problematic URL and see if it loads correctly.
Step 3: If possible, try accessing the page on a different device, like a smartphone or tablet.
Use a Search Engine
If the page has moved, a search engine might help you find its new location.
Step 1: Copy the title or key information from the 404 page.
Step 2: Paste it into a search engine like Google or Bing.
Step 3: Look for results that match the content you’re seeking, possibly on the same website.
Resolving 404 Errors as a Website Administrator
For website owners, addressing 404 errors is crucial for user experience and SEO. Here’s how to tackle them:
Use Google Search Console
Google Search Console is a powerful tool for identifying and fixing 404 errors on your site.
Step 1: Log in to Google Search Console.
Step 2: Select your website property.
Step 3: Navigate to the “Coverage” report under “Index” in the left sidebar.
Step 4: Look for the “Not found (404)” error type in the report.
Step 5: Click on the error to see affected URLs and fix them accordingly.
Implement 301 Redirects
For pages that have been moved or renamed, set up 301 redirects to guide users to the correct location.
Step 1: Identify the old URL causing the 404 error.
Step 2: Determine the new URL where the content now resides.
Step 3: Add a 301 redirect rule in your server configuration or .htaccess file.
For Apache servers, add this line to your .htaccess file:
Redirect 301 /old-page.html https://www.yourwebsite.com/new-page.html
For Nginx, add this to your server block:
location = /old-page.html {
    return 301 https://www.yourwebsite.com/new-page.html;
Fix Broken Internal Links
Regularly audit your site for broken internal links to prevent 404 errors.
Step 1: Use a tool like Screaming Frog SEO Spider to crawl your website.
Step 2: Generate a report of all internal broken links.
Step 3: Update or remove these links in your content management system.
Create a Custom 404 Error Page
A well-designed custom 404 page can improve user experience and keep visitors on your site.
Step 1: Design an informative and helpful 404 page that includes:
  • A clear explanation of the error
  • Links to popular pages or categories
  • A search bar to help users find content
    Step 2: Implement the custom page through your web server configuration or CMS settings.
Monitor External Links
Keep an eye on outbound links to ensure they’re not leading to 404 errors.
Step 1: Use a tool like Ahrefs’ Broken Link Checker to scan your site for broken external links.
Step 2: Update or remove any links pointing to non-existent pages on other websites.
Addressing 404 errors promptly improves user experience and maintains your site’s SEO health. Regular audits and swift action on broken links will keep your website running smoothly and your visitors happy.
