How to Find and Use the Signal Redirector in Atomfall
The Signal Redirector is a crucial tool in Atomfall, allowing players to manipulate power systems and access restricted areas. This device opens up new exploration possibilities and is essential for progressing through certain quests. Let’s dive into how you can acquire and utilize this valuable piece of equipment.
Locating the Signal Redirector
The Signal Redirector is hidden away in the Skethermoor region, an area teeming with hostile Protocol forces. To obtain it, you’ll need to navigate through dangerous territory and infiltrate a secure facility.
Accessing Skethermoor
Step 1: Travel to Wyndham Village and locate the southeast exit.
Step 2: Pass through the gate to enter the Skethermoor region.
Be cautious as you enter Skethermoor. Protocol soldiers are on high alert and will attack on sight unless you’ve previously gained favor with their leader, Sims.
Acquiring the Windfall Keycard
Before you can obtain the Signal Redirector, you’ll need to find the Windfall Keycard.
Step 1: Head to the Protocol Workshop located at coordinates 38.0E, 77.4N.
Step 2: Clear the facility of Protocol soldiers. Be prepared for a firefight.
Step 3: Search the back rooms for a narrow crawlspace.
Step 4: Squeeze through the opening to find a deceased scientist wearing a gas mask.
Step 5: Loot the body to obtain the Windfall Keycard.
Retrieving the Signal Redirector
With the Windfall Keycard in hand, you’re ready to claim your prize.
Step 1: Make your way to the Protocol Field Station at coordinates 41.3E, 74.9N.
Step 2: The station is located in a fenced area between the Ruined Hamlet and Crop Fields.
Step 3: Approach cautiously, as the entire area is considered trespassing territory.
Step 4: Use stealth to avoid BARD Robots and stay low near the river.
Step 5: Find a gap in the fence to slip through and reach the bunker entrance.
Step 6: Inside the Field Station, locate the storeroom adjacent to the locked Armory.
Step 7: Use the Windfall Keycard to open the Windfall Crate.
Step 8: Collect the Signal Redirector and a bonus Training Stimulant from the crate.
Using the Signal Redirector
Now that you’ve acquired the Signal Redirector, it’s time to put it to use. This versatile tool allows you to interact with power conduits and other electrical systems throughout Atomfall.
Basic Functionality
The Signal Redirector works by manipulating power flows. When you’re near an interactive electrical system, the Signal Redirector icon will appear on your HUD.
Step 1: Equip the Signal Redirector when prompted.
Step 2: Aim the device at the power conduit or junction box you wish to manipulate.
Step 3: Activate the Signal Redirector to either reroute power or disable the system entirely.
Practical Applications
The Signal Redirector has numerous uses throughout Atomfall:
  • Unlocking Doors: Redirect power to activate locked doors, granting access to new areas.
  • Disabling Security Systems: Cut power to alarm systems or surveillance cameras to facilitate stealth approaches.
  • Powering Up Equipment: Restore electricity to defunct machinery or computers to uncover new information or activate useful devices.
  • Solving Puzzles: Many environmental puzzles in Atomfall require clever use of the Signal Redirector to progress.
Testing Your Skills
Right in the Protocol Field Station where you found the Signal Redirector, there are two excellent opportunities to practice using your new tool:
  1. The Armory: Use the Signal Redirector on two nearby conduits to reroute power and unlock the Armory door. Inside, you’ll find a cache of valuable weapons and ammunition.
  2. Flooded Room: In the back of the bunker, there’s a flooded room crackling with electricity. Use nearby crates to reach a conduit, then use the Signal Redirector to disable the power. This allows safe access to a BARD loot chest submerged in the water.
Advanced Techniques
As you become more familiar with the Signal Redirector, you’ll discover more creative ways to use it:
  • Chain Reactions: Some areas require you to reroute power through multiple conduits in sequence to achieve the desired effect.
  • Timed Puzzles: Certain scenarios may require quick thinking and fast action with the Signal Redirector to overcome time-sensitive challenges.
  • Combining Tools: The Signal Redirector often works best in conjunction with other equipment. For example, use your Metal Detector to locate hidden conduits, then manipulate them with the Signal Redirector.
The Signal Redirector opens up a world of possibilities in Atomfall. Don’t hesitate to backtrack to previously explored areas – you might find new secrets or shortcuts now that you have this powerful tool at your disposal. Happy redirecting, stalker!
