How to Duplicate a Worksheet into Another Excel Workbook
Copying worksheets between workbooks is essential for efficient data management. This allows you to quickly transfer data across multiple projects without manual re-entry, saving time and ensuring data consistency for better productivity.
Steps to Copy a Worksheet Using Drag and Drop
This is a very effective and quick way to duplicate a worksheet.
Step 1: Open both the workbook containing the sheet you want to copy and the destination workbook.
Step 2: Arrange the two workbooks so that they are both visible on your screen.
Step 3: Click on the worksheet tab you wish to copy.
Step 4: Press and hold the Control key. You should see a “+” sign appear next to the cursor.
Step 5: While holding the Control key, drag the selected worksheet to the destination workbook.
Step 6: Release the mouse button, and then release the Control key.
Step 7: The worksheet will now be copied to the second workbook.
Steps to Move a Worksheet Using Drag and Drop
To move a worksheet (instead of copying), the process is similar, but without pressing the Control key.
Step 1: Open the two workbooks: the source workbook and the destination workbook.
Step 2: Make both workbooks visible on your screen.
Step 3: Select the worksheet you intend to move.
Step 4: Drag the worksheet to the receiving workbook.
Step 5: Release the mouse button to finalize the move.
Step 6: Your worksheet is now moved to the second workbook.
By using these simple methods, you can effectively manage your Excel worksheets across different workbooks, saving time and effort.
