How to Customize Folders in Samsung's One UI 7: Maximizing Home Screen Efficiency
Samsung’s One UI 7, based on Android 15, introduces a range of new customization options that significantly improve the user experience. One standout feature is the ability to enlarge and customize home screen folders, allowing for quicker access to apps and a more organized interface. Let’s explore how this feature works and how you can make the most of it on your Samsung device.
Enlarging Home Screen Folders
One UI 7 allows users to resize their home screen folders, making it possible to view and access apps within the folder without actually opening it. This seemingly small change can have a big impact on your daily smartphone use.
Step 1: Long-press on the folder you want to enlarge.
Step 2: From the pop-up menu, select the Enlarge option.
Step 3: The folder will expand, showing more app icons directly on the home screen.
It’s important to note that the size of the enlarged folder depends on the number of apps it contains. Make sure you have enough free space around the folder before enlarging it.
Customizing Folder Layouts
Beyond just making folders larger, One UI 7 offers additional customization options for folder layouts.
Step 1: Open the enlarged folder by tapping on it.
Step 2: Tap the three-dot menu in the top-right corner of the folder.
Step 3: Select Edit to customize the folder.
From here, you can:
  • Rearrange apps within the folder by dragging and dropping.
  • Remove apps from the folder by dragging them out.
  • Add new apps to the folder by dragging them in from the home screen or app drawer.
  • Change the folder name by tapping on the current name at the top.
Optimizing Folder Usage
To make the most of this new feature, consider these tips:
  1. Group related apps: Create folders for categories like productivity, social media, or entertainment for easy access.
  2. Prioritize frequently used apps: Place your most-used apps in the first few slots of the enlarged folder for quick access.
  3. Use color coding: Customize folder icons or backgrounds to visually distinguish different categories at a glance.
  4. Combine with widgets: Place enlarged folders near relevant widgets to create functional zones on your home screen.
Reverting to Standard Folder Size
If you decide you prefer the original folder size:
Step 1: Long-press on the enlarged folder.
Step 2: Select the Shrink option from the pop-up menu.
The folder will return to its standard size, collapsing the visible app icons.
Additional One UI 7 Home Screen Features
While enlarged folders are a standout feature, One UI 7 offers several other home screen customization options:
  • App icon customization: Change individual app icons or apply icon packs for a cohesive look.
  • Widget stacking: Group multiple widgets in the same space and swipe between them.
  • Custom layouts: Adjust the home screen grid for more precise app and widget placement.
  • Gesture controls: Customize swipe gestures for quick actions from the home screen.
One UI 7’s enlarged folders feature transforms how users interact with their home screens, offering a blend of organization and quick access. By taking advantage of this feature along with other customization options, you can create a home screen layout that’s not only visually appealing but also optimized for your personal workflow. As you explore these new capabilities, you’ll likely discover even more ways to tailor your Samsung device to your preferences, making your smartphone experience more efficient and enjoyable.
