How to Create Custom Keyboard Shortcuts for Chrome Extensions
Chrome extensions can significantly boost your productivity, but constantly clicking icons to activate them can slow you down. Luckily, Google Chrome allows you to set up custom keyboard shortcuts for your favorite extensions, letting you trigger them instantly with a few keystrokes. This feature is built right into Chrome, no extra software required.
Accessing Chrome’s Keyboard Shortcut Settings
To begin customizing your extension shortcuts:
Step 1: Open Google Chrome and click the puzzle piece icon in the top-right corner to view your extensions.
Step 2: Click “Manage Extensions” at the bottom of the dropdown menu.
Step 3: In the Extensions page, click the hamburger menu (three horizontal lines) in the top-left corner.
Step 4: Select “Keyboard shortcuts” from the menu.
You’ll now see a list of all your installed extensions, along with any existing shortcuts and options to add new ones.
Creating a Custom Shortcut
Once you’re on the Keyboard shortcuts page:
Step 1: Find the extension you want to create a shortcut for in the list.
Step 2: Click the pencil icon next to “Not set” (or the existing shortcut if one is already assigned).
Step 3: Press the desired key combination for your shortcut. Chrome requires that shortcuts include at least one of the following modifier keys: Ctrl, Alt, or Shift (on Windows/Linux) or Command, Option, or Shift (on Mac).
Step 4: The shortcut will be automatically saved once you’ve entered a valid combination.
Best Practices for Choosing Shortcuts
When selecting your custom shortcuts:
  • Avoid common system or browser shortcuts like Ctrl+C or Ctrl+T.
  • Use memorable combinations related to the extension’s function (e.g., Ctrl+Shift+A for an ad blocker).
  • Consider using function keys (F1-F12) in combination with modifiers for less commonly used extensions.
  • Be consistent across your extensions to make them easier to remember.
Managing and Modifying Shortcuts
To change or remove an existing shortcut:
Step 1: Return to the Keyboard shortcuts page in Chrome’s extension settings.
Step 2: Click the pencil icon next to the shortcut you want to modify.
Step 3: Enter a new key combination to change the shortcut, or press Backspace to remove it entirely.
Using Global Shortcuts
Chrome also allows you to set “global” shortcuts that work even when Chrome isn’t the active window:
Step 1: On the Keyboard shortcuts page, look for the “In Chrome” dropdown next to an extension’s shortcut.
Step 2: Change it to “Global” to make the shortcut work system-wide.
Note that global shortcuts are limited to specific key combinations (usually Ctrl+Shift+[0-9]) to avoid conflicts with other applications.
Troubleshooting Common Issues
If your custom shortcuts aren’t working:
  • Ensure Chrome is up to date.
  • Check for conflicts with other extensions or system-wide shortcuts.
  • Try disabling and re-enabling the extension.
  • Restart Chrome after making changes to shortcuts.
By setting up custom keyboard shortcuts for your Chrome extensions, you can streamline your browsing experience and work more efficiently. Take some time to configure shortcuts for your most-used extensions, and you’ll find yourself navigating Chrome like a pro in no time.
