Fortnite’s Chapter 6 Season 2 brings an exciting new Story Found quest called “Someone is planning a joyride.” This quest involves teaming up with Cassidy Quinn for a thrilling car heist and getaway. Here’s a detailed walkthrough on how to complete this quest and earn some sweet rewards.
Locating Cassidy Quinn at Lonewolf Lair
To begin this quest, you’ll need to make your way to Lonewolf Lair, a prominent location in the northwest region of the Fortnite map.
Step 1: Land near the main entrance of the mansion at Lonewolf Lair.
Step 2: Look for a small building next to a fountain outside the mansion.
Step 3: Approach Cassidy Quinn, who will be standing outside this building waiting for you.
Initiating the Car Heist
Once you’ve found Cassidy Quinn, it’s time to set the plan in motion.
Step 1: Interact with Cassidy Quinn to open a dialogue menu.
Step 2: Select the “Steal Kane’s car” option from the menu.
Step 3: Follow Cassidy as she moves towards the edge of the mansion where the target vehicle is located.
Stealing Fletcher Kane’s Car
Now comes the exciting part - actually stealing the car!
Step 1: Approach the garage on the left side of the mansion with Cassidy.
Step 2: Wait for Cassidy to unlock the cage surrounding the car.
Step 3: Once the cage is open, quickly enter the vehicle to officially begin the joyride.
Making Your Getaway
After successfully stealing the car, you’ll need to make a clean getaway by following a series of waypoints.
Step 1: Drive through the first waypoint, which appears as a glowing yellow circle near the fountain at Lonewolf Lair.
Step 2: Continue driving through a total of 10 waypoints that will guide you on a curving path from Lonewolf Lair towards Magic Mosses.
Step 3: Keep an eye out for the next waypoint, which will appear after you pass through each one.
Step 4: The final waypoint will be located near a waterfall, marking the end of your joyride.
Tips for a Successful Joyride
- Focus on your surroundings to spot the next waypoint quickly.
- You have 2 minutes to complete the course, which should be plenty of time if you drive steadily.
- Avoid other players and obstacles that might slow you down or damage the car.
- You don’t need to use the boost function, as driving at normal speed is sufficient to complete the course in time.
Completing this quest will reward you with a full level-up in your Battle Pass, making it a worthwhile endeavor for players looking to unlock all the season’s rewards. Remember, this quest can only be completed by one player at a time, so try to be the first to reach Cassidy Quinn at Lonewolf Lair for the best chance of success.
