How to Calculate and Perform Anova Test in Excel
Anova test is a powerful statistical tool in Microsoft Excel, designed to help you identify significant differences between two or more datasets.
Even if the term Anova is new to you, the underlying concept is applicable in many everyday scenarios.
To perform an Anova test in Excel, you’ll need the Data Analysis Toolpak, which simplifies complex statistical analyses. Follow this guide to learn how to calculate and conduct an Anova test in Excel.
Using The Data Analysis Toolpak
This is the most straightforward method, utilizing Excel’s built-in tools for Anova tests.
What is Anova?
Anova, which stands for Analysis of Variance, is a statistical test used to determine if the means of three or more independent groups are significantly different.
It helps ascertain whether the differences between the means of these groups represent genuine differences (between the means of population) or are merely due to chance. Anova is the appropriate choice when comparing variance between three or more groups. For instance, comparing student heights from three different schools.
There are two main types of Anova tests available in Excel:
  • One-Way Anova (or One-Variable Anova test):
The One-Way Anova test is used when you have one independent variable across multiple groups and want to see if it differs from the independent variable.
For example, when comparing test scores from three schools (X, Y, and Z), the school is the independent variable, while the test scores are the dependent variable (dependent on the school’s quality).
Performing a One-Way Anova test on student scores will reveal if each school’s performance differs significantly.
  • Two-Way Anova (or Anova: Two-Factor Test):
The Two-Way Anova test is used when you have two independent variables and want to test how their interaction affects a dependent variable.
Using the same school and scores example, if you want to see how three schools (first independent variable) and their faculty (second independent variable) affect student test scores, you can run a Two-Way Anova analysis.
One-Way Anova test in Excel
Performing a One-Way Anova test in Excel is quite simple. Here’s an example.
Suppose you have test score data from three schools: School X, School Y, and School Z.
Follow the steps below to analyze the variance and see if the mean test scores differ significantly.
The Anova test is part of Excel’s Data Analysis Toolkit, which may not be visible by default. To add it:
Step 1: Go to the File tab.
Step 2: Go to Excel Options.
Step 3: In the left pane, click on Add-ins.
Step 4: At the bottom, select Excel Add-ins and click Go.
Step 5: Check Analysis ToolPak and click Ok.
The Analysis group will now appear in the Data tab.
Step 6: Go to Data tab > Analysis Group > Data Analysis.
Step 7: Select Anova: Single Factor and click Okay.
Step 8: For the Input Range, select the data (including headers).
Step 9: Choose Columns as Grouped By, since your data is in columns.
Step 10: Check Labels in First Row if your data includes headers.
Step 11: Keep the Alpha value at 0.05 for now.
Step 12: Define the Output Range by selecting a cell where the results should populate.
Step 13: Click Okay.
Excel will perform the One-Way Anova test and display the results.
The results may seem complex initially, but the next section breaks them down.
Interpreting the results of the One-Way Anova test in Excel
Here’s how to interpret the One-Way Anova test results for the school test scores example.
Let’s examine what each part tells you about the dataset.
The Summary Table
  • Count: The number of data points (test scores) in each group (school).
  • Sum: The total of all test scores in each group.
  • Average: The mean, calculated by dividing the sum of test scores by the count of students.
  • Variance: How much each school’s test scores deviate from the mean. It’s the sum of squared differences between each score and the group mean.
The Summary table provides basic statistical figures for the dataset.
Anova Table
  • Source of Variation: Data variation can be between different data groups or within the same group.
  • Between Groups: Represents the variance in means of different groups due to the independent variable.
  • SS (Sum of Squares): Calculated as follows:
    1. Find the mean for each group.
    2. Calculate the overall mean for all groups.
    3. Calculate the sum of squares for each group using the formula:
      Sum = Count × (Group Mean−Overall Mean)^2
The sum of squares is the total variation between group means.
  • Df (Degrees of Freedom): Number of groups less 1. In this case, 2 (3 less 1).
    The degree of freedom indicates the number of independent comparisons possible between the groups.
  • MS (Mean Square): The average variation between groups, calculated by dividing the SS by the df.
  • F (F-Statistic):
    The F-statistic formula is:
    F-statistic = Mean Square (Between groups) / Mean Statistic (Within groups)
    It compares the variance between group means and within groups. A higher number indicates more significant differences between means.
  • P-value:
    The P-value comes from the F-distribution table, based on the F-statistic and df.
Remember the Alpha value was set to 0.05 when defining the input data for the Anova test.
The P-value indicates the probability of the null hypothesis (that all group means are the same) being true. A P-value equal to or less than 0.05 rejects the null hypothesis, suggesting at least one group’s mean is significantly different.
  • F crit (F critical value):
    The critical value from the F-distribution table for a significance level (usually 5%) and degrees of freedom.
A 5% P-value (or significance level) is the probability threshold to reject the null hypothesis. This means there is a 5% chance that we will incorrectly reject the null hypothesis, which is acceptable.
Calculations are similar within groups.
Bottom Line for our Anova test
For the test above:
  • F-value: 71.35
  • P-value: 1.66961E-11 (approximately 0.0000000000167)
  • F critical value (F crit): 3.354131
Since the P-value is much smaller than 0.05, the null hypothesis (that all group means are the same) can be rejected.
Also, the F-value (71.35) is significantly greater than 3.354, indicating that the group means differ significantly.
The Anova results show that the mean test scores for schools X, Y, and Z are very different. The independent variable (schools) significantly impacts the dependent variable (test scores).
This is how the Anova table aids hypothesis testing, summarizing the variability in datasets and showing variability between and within groups.
Following this guide, running One-Way Anova tests in Excel becomes straightforward, allowing you to determine if differences in means among independent groups are significant.
