Linux system administrators often need to ensure critical services remain running, even if they crash unexpectedly. While systemd makes this straightforward on modern distributions, older systems using SysVinit or Upstart require different approaches. Let’s explore how to configure automatic service restarts on these non-systemd init systems.
Using Monit with SysVinit
Monit is a versatile monitoring tool that can restart failed services on SysVinit-based systems.
Step 1: Install Monit
# Debian/Ubuntu
sudo apt update && sudo apt install monit
# CentOS/RHEL
sudo yum install monit
Step 2: Configure service monitoring
Edit the Monit configuration file:
sudo nano /etc/monit/monitrc
Add a service definition, for example to monitor Apache:
check process apache2 with pidfile /var/run/apache2/apache2.pid
start program = "/etc/init.d/apache2 start"
stop program = "/etc/init.d/apache2 stop"
if failed host 127.0.0.1 port 80 protocol http then restart
if 5 restarts within 5 cycles then timeout
This configuration tells Monit to:
- Check the Apache process using its PID file
- Use the init script to start/stop the service
- Restart Apache if it can’t reach localhost on port 80
- Stop attempting restarts after 5 failures in 5 check cycles
Step 3: Enable and start Monit
sudo service monit start
sudo update-rc.d monit defaults
Monit will now monitor Apache and restart it if it fails.
Upstart Service Recovery
Upstart, used in older Ubuntu versions, has built-in service recovery options.
Step 1: Create an Upstart job configuration
Create a file for your service in /etc/init/
, for example:
sudo nano /etc/init/myapp.conf
Step 2: Configure automatic restarts
Add the following to your Upstart job:
start on runlevel [2345]
stop on runlevel [!2345]
respawn
respawn limit 10 5
exec /path/to/your/application
This configuration:
- Starts the service on normal runlevels
- Enables automatic restarts with
respawn
- Limits restarts to 10 attempts within 5 seconds
Step 3: Start and enable the service
sudo start myapp
Upstart will now automatically restart your service if it crashes.
Cron-based Service Monitoring
For systems without Monit or Upstart, a simple cron job can periodically check and restart services.
Step 1: Create a monitoring script
sudo nano /usr/local/bin/check_service.sh
Add the following content:
#!/bin/bash
SERVICE_NAME="apache2"
if ! pgrep -x "$SERVICE_NAME" > /dev/null
then
/etc/init.d/$SERVICE_NAME start
echo "Restarted $SERVICE_NAME at $(date)" >> /var/log/service_restarts.log
fi
Step 2: Make the script executable
sudo chmod +x /usr/local/bin/check_service.sh
Step 3: Add a cron job
Edit the root crontab:
sudo crontab -e
Add a line to run the script every 5 minutes:
*/5 * * * * /usr/local/bin/check_service.sh
This method is less immediate than Monit or Upstart, but provides a simple fallback option for service monitoring.
While these methods work well for older systems, consider upgrading to a systemd-based distribution for more robust and integrated service management capabilities. Modern init systems offer improved logging, dependency management, and parallel startup processes that can significantly improve system reliability and performance.
