Having trouble updating your macOS and seeing an error like “Unable to Verify MacOS Update” or “macOS (version) could not be verified”? It’s a frustrating issue, but there are several ways to tackle it. Here’s a breakdown of what you can try.
Method 1: Reinstall macOS from Recovery
This is often the most effective method as it bypasses many potential software conflicts.
For Macs with Apple Silicon:
- Shut down your Mac completely.
- Press and hold the power button until the “Startup Options” screen appears.
- Select “Options” and click “Continue” to enter Recovery Mode.
- Choose a user account and enter your password if prompted.
- Select “Reinstall macOS” and follow the on-screen instructions.
For Macs with Intel Processors:
- Restart your Mac.
- Immediately press and hold
Command + R
keys until the Apple logo appears. - Enter your password if prompted.
- From the Recovery Mode menu, select “Reinstall macOS” and follow the instructions.
Method 2: Erase and Reinstall macOS
If the Recovery method doesn’t work, a clean install can clear out any persistent software problems. Remember to back up your data first!
- Open “Settings” and select “General” from the sidebar.
- Click on “Transfer or Reset” on the right.
- Choose “Erase All Content and Settings”.
- Enter your admin password and click “Unlock”.
- Follow the prompts to back up your data (if you haven’t already) or proceed to erase the Mac.
- Confirm the action and wait for the process to complete. Your Mac will restart to the Setup Assistant.
- During the restart, enter Recovery Mode and reinstall macOS following the steps outlined in “Method 1”.
Method 3: Delete and Redownload the Installer
Sometimes, the installer itself is the problem.
- Open the “Applications” folder on your Mac. Find the installer file (it might be called something like “Install macOS Ventura.app”).
- Drag the installer to the Trash, then empty the Trash to completely remove it.
- Go to “Settings” (or “System Preferences” on older macOS versions). Navigate to “General” in the sidebar and select “Software Update” to download the update again.
If the update isn’t available there, open the App Store and search for the macOS version you want to install (e.g., macOS Ventura). Download the installer directly from the App Store.
Method 4: Restart Your Mac
A simple restart can often clear up temporary glitches.
- Click the Apple icon in the top-left corner of your screen.
- Select “Restart” from the dropdown menu.
Once your Mac restarts, try to install the update again.
Method 5: Check Your Internet Connection
A flaky internet connection can cause verification issues.
- Make sure your Mac is connected to the internet. Check the Wi-Fi icon in the menu bar.
- If you suspect issues, restart your router or try a different network.
Even if you’re using a downloaded installer, macOS might need internet access for verification.
Method 6: Toggle Date and Time Settings
Incorrect date and time settings can also mess with the verification process.
- Open “Settings” on your Mac and select “General” from the sidebar.
- Click on “Date & Time” in the right pane.
- Toggle off “Set time and date automatically” and wait a few seconds.
- Toggle it back on to refresh the settings.
- Restart your Mac and try installing the update again.
Method 7: Install in Safe Mode
Safe Mode can prevent third-party software from interfering with the update.
- Press and hold the Power button until the “Startup Options” screen appears.
- Select your startup disk (usually “Macintosh HD”).
- Hold down the
Shift
key and click “Continue in Safe Mode”. - Log in to your account. You might need to enter your password twice.
- Restart your Mac.
- Immediately press and hold the
Shift
key until the login window appears. - Log in to your account. You might be prompted to log in twice.
- “Safe Boot” should appear in the menu bar on the login screen.
Once in Safe Mode, attempt to install the macOS update again.
Method 8: Repair Disk Using Disk Utility
Disk issues can sometimes prevent updates. Using Disk Utility to repair your disk might help. Back up your data first!
- Open the “Applications” folder and go to the “Utilities” folder.
- Launch “Disk Utility”.
- Click “View” and select “Show All Devices” to display all connected disks and volumes.
- Starting with the last volume on your startup disk, select it and click “First Aid” in the toolbar.
- Click “Run” to begin the repair process. Repeat this for each volume, then the containers, and finally the startup disk itself.
- Once complete, exit Disk Utility and try installing the update again.
Method 9: Check Apple System Status
The issue could be on Apple’s side.
- Visit Apple’s System Status page.
- Make sure the dot next to “macOS Software Update” is green.
If the service is down, you’ll need to wait for Apple to fix it.
By following these steps, you should be able to get your macOS update working.
