Excel Duplicate Removal Guide
Having duplicate data in Excel can really mess up your analysis and reports. Getting rid of them will help keep your data clean and dependable.
Method 1: Using the Remove Duplicates Feature
This is probably the quickest and most straightforward way to delete duplicates.
  1. First, select the range of cells that contains the duplicate entries you want to remove. It can be a specific set of cells or your entire dataset.
    Select dataset
  2. Next, navigate to the Data tab on the Excel ribbon. In the Data Tools section, you’ll find the Remove Duplicates button; click on it.
  3. A Remove Duplicates dialog box will pop up, showing all the column headers in your selection. Check the boxes next to the columns where you want Excel to look for duplicates. If your dataset has headers, make sure to check the “My data has headers” option. Then, hit OK.
  4. Once you hit OK, Excel will let you know how many duplicates were found and removed, and how many unique values are left. Click OK to confirm the removal.
    Duplicate removal message
This method removes duplicate rows completely based on your specified columns, so you’re left with only unique data.
Method 2: Finding Duplicates Using Conditional Formatting
This is a great way to visualize duplicates before you decide to remove them, giving you a chance to review the data first.
  1. Start by selecting the cell range where you suspect you have duplicate entries. For this example, let’s say we’re focusing on duplicate names within the “Representatives” column.
    Selecting Representatives column
  2. Go to the Home tab, then click on Conditional Formatting. Hover over Highlight Cells Rules and choose Duplicate Values….
    Conditional Formatting Menu
  3. In the Duplicate Values dialog, choose to highlight either duplicate or unique values using the first dropdown. Select “Duplicate.” Use the second dropdown to pick the highlighting style. Click OK to apply the formatting.
  4. Excel will now highlight all duplicate entries in your selected range. This helps you visually identify them.
    Highlighted duplicates
  5. If you want to remove the highlighting, just select the highlighted cells, navigate back to Conditional Formatting, click on Clear Rules, and then select Clear Rules from Selected Cells.
This method allows you to spot duplicates easily, giving you flexibility in managing your data.
Method 3: Removing Duplicates Using Advanced Filters
This approach is handy when you want to either filter out duplicates directly or copy only unique data to a different location, without messing with the original dataset.
  1. Begin by selecting the data range that you need to filter for duplicates.
    Select dataset
  2. Go to the Data tab, and click on Advanced in the Sort & Filter group.
    Data tab, Advanced Filter
  3. In the Advanced Filter dialog, if you want to filter the original data range, choose “Filter the list, in-place”. Then, check the box for “Unique records only”, and click OK.
    Advanced Filter dialog - Filter in place
  4. Excel will now hide all duplicate rows, displaying only unique records in your dataset.
    Filtered unique records
  5. Alternatively, if you’d rather copy unique records to a new spot, choose “Copy to another location” in the Advanced Filter dialog. Then, specify the “Copy to” range using cell references, making sure “Unique records only” is checked, and then click OK.
    Advanced Filter dialog - Copy to another location
  6. Now, the unique records will be copied to the specified location, leaving your original dataset untouched.
    Unique records copied
This method is great for extracting unique values without changing your original data, and it is also handy for working with unique data in different parts of your sheet.
Keeping your Excel data free from duplicates will guarantee more precise and reliable data analysis. By using these features, you can easily identify and remove duplicates, leading to cleaner, more trustworthy data.
