Enabling Pop-ups on Your iPhone
Okay, so pop-ups on your iPhone can be a real headache, right? They’re annoying on a computer, but it’s a whole other level of frustration when they pop up on a smaller screen. iPhones automatically block them, which is great most of the time. But sometimes, this pop-up blocking can stop a website from working correctly.
Many sites, especially banking and financial ones, rely on pop-ups. If you are taking tests or exams online, those sites often use them, too.
While we can all agree that relying on pop-ups isn’t the best design, the fact is, sometimes you need to allow them for certain websites to work. The good news is, it’s pretty easy to allow pop-ups on your iPhone.
Method 1: Allowing Pop-Ups in Safari
If you’re an Apple Safari user, here’s how to turn those pop-ups back on:
  1. Open your iPhone’s Settings app and scroll down until you find “Safari,” then tap it.
  1. Look under the ‘General’ settings and find the ‘Block Pop-ups’ option. Tap the toggle to switch it off so it’s no longer green.
That’s it! Safari will now allow pop-ups on every website you visit.
Method 2: Allowing Pop-Ups in Chrome
If you’re using Google Chrome as your browser, the process is slightly different. Here’s how to do it:
  1. Open the Chrome app on your iPhone. Then, go to the three-dot “More” menu at the bottom right corner of the screen.
  1. In the menu that pops up, select “Settings”.
  1. Scroll down in settings and tap on “Content Settings”.
  1. Select “Block Pop-ups” to open those settings.
  1. Tap the toggle to turn off “Block Pop-ups” so it’s no longer blue.
  1. Finally, tap “Done” in the top right-hand corner.
Chrome will now let those pop-ups through on any sites you visit.
It’s worth noting that it’s usually best to only disable pop-up blocking temporarily. Once you’re done with the site requiring pop-ups, it’s a good idea to switch the blocking back on, or you’ll be getting pop-ups everywhere.
