Enabling Remote Desktop on Windows 11 allows you to connect to your computer from another device on the same local network, giving you remote access to files, applications, and resources. This is made possible by the Remote Desktop Protocol (RDP). Windows 11 provides several methods to enable this feature, including using the Settings app, Control Panel, Command Prompt, and PowerShell.
Enable Remote Desktop from Command Prompt
For experienced users, Command Prompt offers a direct way to configure Remote Desktop.
Step 1: Open Start
Step 2: Search for Command Prompt
, right-click the top result, and select the Run as administrator option.
Step 3: Type the following command to enable the remote desktop protocol and press Enter
reg add "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server" /v fDenyTSConnections /t REG_DWORD /d 0 /f
Step 4: (Optional) Type the following command to enable remote desktop through the Windows Firewall and press Enter
netsh advfirewall firewall set rule group="remote desktop" new enable=Yes
Once you complete the steps, the features will be enabled, and the firewall will be configured, allowing you to access the computer remotely.
Enable Remote Desktop on Windows 11
Enabling Remote Desktop via the Settings app offers a user-friendly approach.
Step 1: Open Settings
on Windows 11.
Step 2: Click on System
Step 3: Click the Remote Desktop
page.
Step 4: Turn on the Remote Desktop
toggle switch.
Step 5: Click the Confirm
button.
Once you complete the steps, you can connect to your computer using the modern Remote Desktop app (recommended).
The system will grant the current user permission to access the computer remotely. To grant access to another user, click the "Remote Desktop users"
setting on the page, click the "Add"
button, and specify the user.
The Remote Desktop feature uses the "Network Level Authentication"
option to make the connection more secure. The settings page also displays the current "Remote Desktop"
port in case you need to configure a router to allow remote connections outside the network. If nothing changes on your machine, the port number should always be "3389"
Enable Remote Desktop from PowerShell
PowerShell offers another command-line method for enabling Remote Desktop.
Step 1: Open Start
Step 2: Search for PowerShell
Set-ItemProperty -Path 'HKLM:SystemCurrentControlSetControlTerminal Server' -name "fDenyTSConnections" -value 0
Step 4: (Optional) Type the following command to turn on the remote desktop feature through the Windows Firewall and press Enter
Enable-NetFirewallRule -DisplayGroup "Remote Desktop"
After completing the steps, you can use the Remote Desktop app on Windows 11 to access the device remotely, even when the firewall is enabled.
Enable Remote Desktop from Control Panel
While less direct than the Settings app, the Control Panel provides another way to configure Remote Desktop.
Step 1: Open Control Panel
Step 2: Click on System and Security
Step 3: Under the “System” section, click the "Allow remote access"
option.
Step 4: Under the “Remote Desktop” section, select the "Allow remote connections to this computer"
option.
Step 5: Click the Apply
button.
Step 6: Click the OK
button.
After you complete the steps, you can connect to your device remotely using the Remote Desktop app on another computer.
When you enable the feature using the Control Panel, the option to require "Network Level Authentication"
also gets selected by default.
Troubleshooting Tips
- Remote Desktop Option Missing: This feature is not supported by the “Home” edition of Windows 11. Confirm you’re using Windows 11 Pro or Enterprise.
- Unable to connect remotely: Verify that the computer is turned on and connected to the network and that the remote desktop is enabled. Also, check firewall settings to ensure Remote Desktop connections are allowed.
- Network-Level Authentication (NLA) issues: If you experience problems with NLA, you can disable it (not recommended for security reasons) by unchecking the option in the Remote Desktop settings. NLA requires users to authenticate before establishing a session, adding an extra layer of security.
Practical Use Cases
The ability to connect remotely to another computer can be useful in many scenarios. For example:
- Access your work computer from home to utilize applications and files as if you were physically present.
- IT professionals can troubleshoot and manage client computers remotely, reducing the need for on-site visits.
- Retrieve personal files or manage downloads on your home computer while away.
Enabling Remote Desktop on Windows 11 offers convenient remote access to your computer from other devices on your network. Choose the method that best suits your technical expertise and enjoy the flexibility of remote connectivity.
