WhatsApp’s latest update brings an exciting feature that lets you generate custom GIFs using Meta AI right in your chats. This powerful tool allows you to describe your desired animation and have it created instantly, ready to share with your contacts. Here’s how to use this new feature:
Launch WhatsApp and open the chat where you want to send your custom GIF. Look for the paperclip icon (attachment) next to the text input field and tap it.
At the bottom of the options, you’ll see a new choice labeled ‘Imagine’. Tap this to access the Meta AI feature.
If this is your first time using Meta AI, you’ll see a brief introduction. Simply tap ‘Continue’ to proceed.
Now comes the fun part – describe the GIF you want to create. Be as specific or creative as you like in the text box provided.
As you type, Meta AI will start generating an image based on your description. Once you’re satisfied with the result, tap the arrow button to the right of the text box.
To transform your static image into a GIF, tap the ‘Animate’ button.
- Your custom GIF is now ready! Hit the ‘Send’ button to share it in your chat.
Important tips for using Meta AI GIF creation
Ensure you’re running the latest version of WhatsApp to access this feature. Check your app store for any available updates.
Meta AI isn’t just for GIFs – it can answer questions, summarize text, and offer suggestions, much like other AI chatbots.
The AI uses Meta’s Llama 3.1 model, an open-source system that rivals OpenAI’s GPT-4 in capability.
Not happy with your GIF? No problem – just tap ‘Retry’ to start over with a new creation.
