Ever notice how websites seem to remember your login info or shopping cart? That’s thanks to cookies! But sometimes these handy little data packets can cause a site to act up. If a website is misbehaving, clearing its cookies is often the first thing to try. The good news is you don’t have to wipe out all your browser cookies. You can remove them just for the problematic site! Here’s how to do it in Edge, Chrome, and Firefox.
Removing Cookies for a Specific Website in Edge
Microsoft Edge is a popular choice, so let’s cover it first. Here are the steps to delete cookies just for one site.
Method 1: Using the Address Bar
The fastest way to do this is straight from the address bar.
- Go to the website you want to clear cookies from. Then, click on the “Lock” icon (usually to the left of the address). Next, select “Cookies” from the menu. A separate window will pop up.
- Now, you’ll see a list of cookie categories. Click a category and then click the “Remove” button. Do this for each category to clear all the website’s cookies.
Method 2: Through Settings
Alternatively, you can access cookie settings through the main menu:
- Click the “ellipsis” icon (three horizontal dots) and then click on “Settings” from the menu to get started.
- On the left sidebar, click “Cookies and site permissions.”
- Next, on the right side, click on the “Manage and delete cookies and site data” tile.
- Click the “See all cookies and site data” option.
- You can then either use the search bar or manually scroll to find the website. Click on the website when you locate it.
- Click the “Trash” icon to delete all the cookies for the website. Repeat for each category if there are multiple.
Removing Cookies for a Specific Website in Chrome
Got a Chrome browser? Here’s how to clear cookies for just one website.
This is the quickest way if you’re already on the site.
- When on the website you want to clear cookies for, click the “lock” icon in the address bar and choose “cookies”. A separate window will appear.
- Select a cookie category and then click the “Delete” button. Repeat this for all categories.
You can also clear cookies through the settings menu.
- From the Chrome home screen, click the “kebab menu” (three vertical dots) icon, and select “Settings”.
- Click on “Security & Privacy” on the left sidebar.
- In the right section, click the “Cookies and other site data” tile.
- Scroll down and select “See all cookies and site data”.
- You can search for a specific site or scroll to find it.
- Click the “Trash” icon next to the website to delete its cookies.
Removing Cookies for a Specific Website in Firefox
For Firefox users, the steps are similar to Chrome, with a few minor tweaks.
This is the quickest way if you are already on the problematic website.
- Click on the “lock” icon located in the address bar. Then, choose “Clear cookies and site data.”
- Now, simply click “Remove” to delete the cookies for that specific website.
Alternatively, you can access cookie settings through the menu.
- Click on the kebab menu (three vertical dots) located in the top right corner and then select “Settings.”
- Click on the “Privacy & Security” tab on the left sidebar.
- Then, click the “Manage Data” button. A new window will open.
- Find the website either by searching or scrolling, select the website and click the “Remove Selected” button.
If you’re interested in deleting all cookies or clearing cookies after each session, check out this article.
