Season 24 of Apex Legends introduces a fresh set of upgrades that can dramatically alter a Legend’s effectiveness. These Evo Perks are critical for maximizing your Legend’s potential, especially with the changes in Takeover.
Along with extensive modifications to Apex’s assault class, certain Legends, such as Ash and Ballistic, have undergone considerable enhancements, primarily through new upgrades introduced in Season 24. If you aim to optimize your preferred Legend this season, continue reading.
Table of contents
All season 24 legend upgrades in Apex Legends
Since their introduction, upgrades provide players the option to select one of two enhancements upon leveling their shields to Blue (level two) and Purple (level three). It’s important to note that you cannot equip two upgrades of the same level simultaneously, and once a choice is made, it remains fixed for the duration of the match.
Alter
Level Two
Ringmaster: Gain access to Ring Consoles.
Void Vision: Extend highlights and see health bars after exiting tactical.
Level Three
Multidimensional: (New to season 24): Gives second ult charge and allows two Void Nexuses to exist at the same time.
Tactical Cooldown+: Reduce tactical cooldown by 10 seconds.
Ash
Level Two
Dual Breach (New to season 24): Phase Breach ultimate now gets two charges.
Greedy Snare: Arc Snare duration is tripled and can catch multiple enemies.
Level Three
Ghost in the Machine (New to season 24): Dash passive now gets two charges.
Twin Snares: Gain an Arc Snare charge.
Ballistic
Level Two
Killing Time (New to season 24): Increase ult duration 15 seconds.
Lasting Bullet: Smart Bullet duration is tripled.
- Smart Bullet and Overheat effect lasts for 24 seconds instead of eight.
Level Three
Extra Bullet (Buffed in season 24): Double your smart bullet charge (max four shots).
Quiet Time (New to season 24): If the enemy hit by Whistler overheats, they will be silenced for a short time.
Bangalore
Level Two
Tactical Cooldown: Reduce tactical cooldown by five seconds.
Ultimate Cooldown+: Reduce ultimate cooldown by 60 seconds.
- Rolling Thunder cooldown decreased from 240 seconds to 180 seconds.
Level Three
Refuge: Regen HP while inside Smoke.
- Regen works like Octane’s Swift Mend at 3.5 HP per second.
Cover Me: Auto-Ping enemies who trigger Double Time.
Bloodhound
Level Two
Odin’s Glare: Double the duration of tactical’s full-body highlight.
- Increased from one second to two seconds.
Raven’s Blessing: White Ravens charge ultimate by 20 percent when activated.
- Reduces 36 seconds from Beast of the Hunt’s 180-second charge time.
Level Three
Sighthound: Reduce tactical cooldown by 50 percent while ultimate is active.
- Reduces 12 seconds from Eye of the Allfather’s 25-second cooldown.
Flock: Remove enemy range requirement for White Raven spawns.
Catalyst
Level Two
Sister Spikes: Increase max number of active Spikes by one.
- Max number of active Spikes increased from two to three.
Long Veil: Increase Spike throw range by 40 percent.
- Length increased to 55m from 40m.
Level Three
Ferro-Door: Fully rebuild and reinforce missing doors with Passive.
Resilient Veil: Increase ultimate lifetime by five seconds.
- Lifetime increased to 20 seconds from 15 seconds.
Caustic
Level Two
Parabolic Force: Increase tactical throw range by 75 percent.
Residual Toxins: Nox Vision persists for longer.
Level Three
Breathe It In: Regenerate HP while enveloped in Nox Gas.
- Regenerate HP like Octane’s Swift Mend
Particle Diffuser: Increase ultimate area of effect by 50 percent.
Conduit
Level Two
Battpack: Plus one to battery stack limit. See battery count of death boxes.
Bigger Jam: Each ultimate jammer’s damage radius increased by 10 percent.
Level Three
Split Charge: Gain a tactical charge but halve shield regen duration.
- Decreased shield regen from eight seconds to four seconds.
Radiant Transfer: Increase tactical range by 10 meters.
Crypto
Level Two
Off the Grid: Crypto cloaks when in drone.
- Creates an audible cloaked sound effect, like the Surveillance Drone’s buzzing for nearby enemies.
- Threat Vision related skills will not reveal Crypto.
Network Expansion: Passive and ult range increased by 25 percent.
- Surveillance Drone now detects from a 37.5m distance instead of 30m.
- EMP now affects all players in a 37.5m radius instead of 30m
Level Three
Satellite Imagery: Drone scan persists for 1.5 seconds. Ult now scans any enemies hit for four seconds, tracking through walls.
Hackathon: Double drone recharge rate; gain speed boost when it explodes.
- Recharge time reduced from 40 seconds to 20 seconds.
- 30 percent speed boost, like Bangalore’s Double Time.
Fuse
Level Two
Scar Tissue: Take less damage and ignore slow effects from The Motherlode.
Level Three
Wreckless: Take 50 percent less explosive damage.
Knuckle Hustler: Short speed boost on successful Knuckle Cluster hit.
Gibraltar
Level Two
Fast Shotties: Moves faster with shotguns. Auto-reload shotguns on knocks.
Big Bruddah: Increase ult radius by 20 percent.
Level Three
Baby Bubble: Reduce tactical size and cooldown by 25 percent.
- Size reduced from six meters to 4.5 meters.
- Cooldown reduced from 30 seconds to 22.5 seconds.
Bubble Bunker: Increase tactical lifetime by four seconds.
- Dome of Protection lasts for 16 seconds instead of 12 seconds.
Horizon
Level Two
Battpack: Plus shield battery stack limit. Shield battery count shown above deathboxes.
Big Bang: See nearby ordinance through walls and on death boxes.
Level Three
Tactical Cooldown: Reduced tactical cooldown by five seconds. (30 seconds to 25 seconds)
Ultimate Cooldown: Reduce ultimate cooldown by 30 seconds. (210 seconds to 180 seconds)
Lifeline
Level Two
Extended Flight: Increase time before D.O.C. runs out of glide fuel by 1.5 seconds.
Level Three
Enhanced Radio: Increase distance you can assign D.O.C. to teammates from by 50 percent.
Loba
Level Two
Wolf’s Claws: Faster weapon draw and speed boost after translocating.
Shopping Spree: Loba can take an extra item from Black Markets.
Level Three
Brand New Bag: Grants entire squad gold backpacks when upgrade is selected.
Escape Artist: After translocating, regenerate 50 shields.
Mad Maggie
Level Two
Shots Shots Shots: Auto-reload shotguns on knock.
Fire Ball: Wrecking Ball catches fire and explodes in thermite.
Level Three
Big Drill: Increase depth and width of tactical by 50 percent.
Drillslinger: Gain a Riot Drill charge; reduce active duration by 25 percent.
- Each Riot Drill lasts for six seconds instead of eight seconds.
Mirage
Level Two
Renaissance Man: Can now use Survey Beacons, Ring Consoles, Munition Boxes, and scan Care Packages.
Boozle-Eye: Successful bamboozles also highlight enemies for short time.
Level Three
Me Two: Gain a decoy charge (can have both active at once)
- Pressing the interaction key allows Mirage to control both at the same time.
Bamboozle Bonus: Refresh tactical on successful bamboozles.
- Can trigger from Life of the Party decoys.
Newcastle
Level Two
Hero’s Hustle: Increase revive move speed.
Swift Shield: Increase Mobile Shield speed to weapon sprint speed, reduces cooldown by eight seconds.
Level Three
Stronghold: +500 Castle Wall HP; extend energized barrier duration to three minutes.
Ultimate Savior: Castle Wall slam grants 15 seconds of shield regen to each ally in impact area.
Octane
Level Two
Mad Hops: Gain an extra Launch Pad charge.
Thick Skin: Take five less Stim damage. (20 health to 15 health)
Level Three
Airborne Agility: Change directions with the Launch Pad double-jump.
Pathfinder
Level Two
Field Research: Gain access to Survey Beacons.
Pathfinder’s Insider Knowledge Passive will reward 50 percent ultimate charge and a permanent 15-second ultimate cooldown when scanning either Survey Beacons or Ring Consoles with the level two legend upgrade.
Level Three
Zipline Zen: Take 25 percent less damage when riding energized Ziplines.
- Ziplines created from Pathfinder’s ultimate are energized for their first 30 seconds upon creation.
Down and Away: Grapple cooldown resets on knock.
- Will refresh on both knocks and assisted knocks within a three second window.
Rampart
Level Two
- Ultimate reduced from 120 seconds to 90 seconds.
Bandolier: Carry extra ammo per stack.
Level Three
Ramped Up: Improved Mobile Sheila handling and spin-up time by 20 percent.
- Move at standard walking speed when firing/ADS with Sheila.
- Spin-up time reduced from 1.25 seconds to one second.
Amped Reloads: Reload faster with Sheila or when behind Amped Cover.
- Reloading is 50 percent faster while Amped Cover’s wall is up.
Revenant
Level Two
- 120 seconds to 90 seconds.
Murder Machine: Call out the number of squads within 150 meters after a squad wipe.
Level Three
Grim Leaper: Shadow Pounce cooldown resets on knock.
- 25 seconds to 20 seconds
Seer
Level Two
Ultimate Cooldown: Reduce ultimate cooldown by 20 percent.
Artist’s Reach: Increase the throw range of Ultimate by 20 meters.
- Increased from 15m to 35m.
Level Three
Split Focus: Gain a tactical charge, but decrease silence duration by 50 percent.
- Silence duration reduced from eight seconds to four seconds.
Long View: Increase passive and tactical range to 75m.
- Heart Seeker increased from 50m to 75m.
- Focus of Attention increased from 60m to 75m.
Valkyrie
Level Two
Full Coverage: Widen Missile Swarm from 4x3 to 3x5.
Afterburners: Launch 15 percent higher with Skyward Dive.
Level Three
Full Tank: Increase Jetpack fuel by 25 percent.
Eyes in the Sky: Enemies are revealed from farther away and through walls while skydiving.
Vantage
Level Two
Ultimate Reload: Ultimate Accelerants grant two more bullets.
- Ultimate Accelerants provide four bullets instead of two upon use.
Level Three
Sharpshooter: Refresh tactical on hits with ultimate.
Bat Bounce: Improve tactical’s double-jump.
Wattson
Level Two
Revive Expert: Revive teammates faster and with health regen to full health.
Falling Stars: Pylon interceptions spawn Arc Stars at its base.
- Enemy attacks only.
- 1.5 second cooldown between spawns.
- Arc Stars must be picked up before more than five can be spawned.
Level Three
Emergency Power: Doubles ult shield generator rate and capacity.
- Restore one shield every 0.1 seconds instead of 0.2 seconds.
- Pylon can now recharge 500 shields, shared between all legends, instead of 250.
Power Pylon: Double ultimate’s HP and placed ultimates regain charge.
- Increased from 150 HP to 300 HP.
Wraith
Level Two
Sixth Sense: Passive triggers when nearby squad count increases.
Ultimate Cooldown+: Reduced ultimate cooldown by 60 seconds (180 seconds to 120 seconds)
Level Three
Fast Phase: Reduce tactical wind-up by 20 percent (1.25 seconds to one second).
Tactical Cooldown: Reduce tactical cooldown by five seconds (25 seconds to 20 seconds)
These upgrades promise to significantly impact gameplay, providing players with more strategic choices to align with their individual play styles. Exploring and mastering these upgrades is essential for gaining a competitive edge in Season 24.
