Acing Valentine's Quest Chapter 1 in Dress to Impress: A Guide
Valentine’s week brings a special update to the popular Roblox fashion game, Dress to Impress. This update includes new dresses, a redesigned lobby, and the Valentine’s quest, split into two chapters. This guide provides a walkthrough on completing Chapter 1 of the Valentine’s quest.
How to Start DTI Valentine’s Quest Chapter 1
Before beginning the quest, you must go through the portal in the waiting lobby. After a runway competition, the portal is located near the garden entrance. Entering it will transport you to the quest lobby.
Step 1: To start the Valentine’s quest, get on one of the Chapter 1 trains. You can join solo or with a party of two, four, or six players.
Step 2: Find the gate in the garden to start the first cutscene.
Step 3: You can skip the cutscene by pressing the button in the bottom right corner of your screen.
Dress to Impress Valentine’s Quest Chapter 1 Part 1
Method 1: Efficient Potion Brewing Strategy
The most effective strategy involves memorizing potion combinations. Pay close attention to the potions shown for each cauldron, quickly identify the correct bottles, and precisely mix them. Speed is key, so minimizing errors will save significant time.
Method 2: Standard Potion Brewing
Step 1: After the cutscene, proceed down the hallway and turn left just before the end to reach the cauldron room. Another cutscene will play, starting your first task.
Step 2: To complete the task, approach each cauldron in the room.
Step 3: When you stand in front of a cauldron, you will see two potions. Remember these.
Step 4: Choose the correct bottles, and mix them by moving the mouse (up/down or left/right).
Step 5: Repeat the mixing process three times for each bottle.
Step 6: Take the potions to the large cauldron next to the Leah Ashe NPC.
Step 7: You must brew and submit all six potions before the time runs out to complete the task. Watch the timer in the bottom left corner. Failure to finish in time restarts the task from the lobby. Quests can require significant effort.
Dress to Impress Valentine’s Quest Chapter 1 Part 2
Step 1: After finishing the potion task, enter the portal in the potion room to start part 2 of Chapter 1, the shoot-the-heart mission.
Step 2: Gain points by hitting the hearts.
Step 3: Fill the bar on the left to 100% to finish. Keep an eye on the timer at the top.
Step 4: Hitting Golden Hearts grants more points.
That’s how to finish Chapter 1 of the Valentine’s quest in Dress to Impress. Feel free to share your progress and thoughts on Chapter 2 in the comments.
