Accessing clipboard history on Mac: A comprehensive guide
While the built-in clipboard functionality is limited on Mac, there are ways to enhance your copy-paste experience.
Quick facts about Mac clipboard
  • The default Mac clipboard only stores the last copied item
  • You can view the primary clipboard contents, but not its history
  • Mac has a secondary clipboard, but it’s not easily accessible
  • Third-party clipboard managers are the best solution for tracking clipboard history
Method 1: Use a third-party clipboard manager (Most effective)
For those who frequently juggle multiple pieces of information, a third-party clipboard manager is the way to go. Maccy is an excellent, open-source option that’s both lightweight and feature-rich.
Here’s how to get started with Maccy:
  1. Download Maccy from their official website for free, or purchase it from the Mac App Store for $9.99 to support the developers.
  2. Once installed, launch Maccy. It will appear in your Menu Bar for easy access.
  3. To view your clipboard history, simply click the Maccy icon in the Menu Bar. You’ll see a list of recently copied items.
  1. For seamless usage, set Maccy to launch at login. Click ‘Preferences’ in the Maccy menu.
  1. In the Preferences window, check the ‘Launch at Login’ option.
  1. Maccy offers a privacy feature to exclude certain apps from clipboard tracking. This is crucial for sensitive information.
  2. To set up app exclusions, go to the ‘Ignore’ tab in Preferences, ensure you’re on the Applications tab, and click the ‘+’ icon.
  1. Select the apps you want Maccy to ignore, such as password managers or banking apps.
Method 2: View the primary clipboard (Less effective)
While this method doesn’t provide a history, it allows you to see the current clipboard contents:
  1. Open Finder on your Mac.
  2. In the menu bar, navigate to Edit > Show Clipboard.
  1. A window will appear displaying the last item you copied or cut.
Method 3: Utilize the secondary clipboard (Least effective)
Mac has a lesser-known secondary clipboard, accessible through keyboard shortcuts:
  • Cut: Ctrl + K
  • Paste: Ctrl + Y
This method is limited:
  • It only works in text editors
  • You can’t view its contents
  • It may not function in all apps
  • There’s a risk of data loss if the paste function fails
Given these limitations, it’s recommended to stick with the primary clipboard or a third-party manager for important data.
By implementing one of these methods, particularly a robust clipboard manager like Maccy, you can significantly enhance your productivity and never lose track of important copied information again.
