A Definitive Guide on How to Center Text in Excel
Data alignment is a key aspect of working with Excel, especially when your data includes text. Centering text is more than just aesthetics; it improves readability, making your spreadsheets more impactful for reports, dashboards, and forms.
In this guide, we’ll explore several effective methods to center text in Excel.
Center Text Across Multiple Cells
When you need to center text over several cells, here are two approaches:
Center text across selection
This method centers text across a selection of cells without merging them.
Step 1: Select the range of cells where you want the text to appear centered.
Step 2: Access the Format Cells dialog box by either:
  • Clicking the small arrow in the bottom-right corner of the Alignment group on the Home tab.
  • Pressing Ctrl + 1.
Step 3: In the Format Cells dialog box, go to the Alignment tab.
Step 4: In the Horizontal alignment section, choose Center Across Selection from the dropdown menu.
Step 5: Click OK.
This makes the text visually centered across the selected cells. Note that the text is still technically located in the first cell of the selection (check the formula bar). Entering data in any of the other selected cells will cause the centering to adjust to the remaining empty cells.
Center Text by Using Merge and Center
The Merge & Center feature combines selected cells into a single cell and centers the text within it.
Step 1: Select the range of cells you want to merge and center.
Step 2: Go to the Home tab, find the Alignment group, and click Merge & Center.
Step 3: The selected cells will become one large cell, with the text centered inside.
Be cautious: If the cells you are merging contain data, Excel will merge the cells but will only retain the content of the upper-left cell.
Merging cells can sometimes complicate sorting and filtering data in your spreadsheet.
Center Text from the Alignment Buttons
This is perhaps the most straightforward way to center text within a cell.
Step 1: Select the cell or range of cells you want to center.
Step 2: Navigate to the Home tab on the Excel ribbon. Locate the Alignment group. Click the Center alignment button (it looks like four horizontal lines, centered).
The text in your selected cell(s) will now be centered. Any new text added to these cells will also be automatically center-aligned.
Center Text Using Keyboard Shortcut Keys
For those who prefer using the keyboard:
Step 1: Use the arrow keys while holding down the Shift key to select the cells.
Use the down arrow to extend the selection downwards, and the right arrow key to extend it to the right.
Step 2: Press Alt + H to activate the Home tab.
Step 3: Press A, then C (sequentially, not at the same time).
The sequence Alt > H > A > C will center the text in the selected cells.
Center Text by Indenting It
This method uses indentation to visually center text.
Step 1: Select the cell containing the text you wish to center.
Step 2: Go to the Home tab > Alignment group, and click the Increase Indent button.
The Increase Indent button is represented by a right arrow pointing through centered lines.
Step 3: Keep clicking this button until the text appears centered.
Note that this approach only visually centers the text by indenting it. The text isn’t actually center-aligned. You’ll need to repeat these steps for each cell because the amount of indentation needed depends on the length of the text in each cell. Also, if you add more text to a cell, it won’t automatically remain centered.
This guide provides you with several techniques to center text in Excel, suiting different needs and preferences.
